Old 09-20-2003, 09:16 PM   #1
DC Thomas
engine switch
I have a 69 c-10 2wd with 245 six cyln and three on a tree, all factory. I have a 305 V-8 that is now hookewd up to an auto trans. I want to installl the 305 with a 4spd Saginaw manual trans. Do I need to get different flywheel and housing, or will the six cyln fit?
DC Thomas is offline   Reply With Quote
Old 09-20-2003, 09:33 PM   #2
crazy longhorn
Fabricate till you "puke"
the clutch pcs from your 250 will bolt right on the 305. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-20-2003, 10:54 PM   #3
Locutus
Locutus's Avatar
is the 6cyl 3 on the tree the same as a 350? if so I might be intrested in your 3 speed and parts if you do the swap.
Locutus is offline   Reply With Quote
Old 09-21-2003, 12:31 AM   #4
jimfulco
Be sure you put a pilot bearing in the crank.
jimfulco is offline   Reply With Quote
Old 09-21-2003, 07:25 AM   #5
DC Thomas
engine switch
Thanks to all that responded. It appears I was right and my friend wrong... haha!
Locutus, I am not going to do this for a couple months, and I am not sure if it will fit.
DC
