Old 01-20-2016, 08:59 PM   #1
cleszkie
cleszkie's Avatar
LED Instrument Cluster Light Bulbs
I'm wanting to light up my instrument cluster a bit better. Has anyone replaced their stock instrument cluster light bulbs with LEDs? If so, do you have any part numbers for the direct replacement bulbs? Thanks.
cleszkie is offline   Reply With Quote
Old 01-20-2016, 10:33 PM   #2
dirish
dirish's Avatar
Re: LED Instrument Cluster Light Bulbs
I put green led's in my Blazer. I think I just typed in 194 bulb led.
I did my ac heater control bulbs led as well. It's kind cool, and pretty cheap.
dirish is offline   Reply With Quote
Old 01-21-2016, 12:05 AM   #3
hemi43
hemi43's Avatar
Yup, 194s.
I'm using them for my side markers
hemi43 is offline   Reply With Quote
Old 07-11-2016, 03:10 PM   #4
AnotherWs6
AnotherWs6's Avatar
Can we get a little more in depth than just a 194? Are there go to brands, colors etc? Who has some pics that they can share. There is a surprisingly little amount of info on this forum, I have been searching. Also, what about just using the higher watt version of a 194? I believe it is an 18xx or something. Let's get this set once and for all and then make a sticky out of it!
I'm not looking for anything crazy, just to be able to reasonably readmy gauges at night. Thanks!
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 07-12-2016, 02:11 PM   #5
ochre1971
ochre1971's Avatar
I recently changed mine to LED's. I used these off of Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Worked fine, a big improvement for visibility. They dim a bit with the dimmer control, but not a huge range. There may be better options out there for dimming, not sure.
The high beam indicator and turn signals I just left in regular incandescent bulbs, the LED's didn't add any benefit in those locations.
ochre1971 is offline   Reply With Quote
Old 07-12-2016, 02:35 PM   #6
AnotherWs6
AnotherWs6's Avatar
How is the color? Would like something with a greenish tint.
Old 07-12-2016, 02:48 PM   #7
ochre1971
ochre1971's Avatar
These are very white. I would think you'd be able to find simliar green ones online.
Old 07-12-2016, 03:15 PM   #8
dennis7222
dennis7222's Avatar
Go to superbrightleds.com They have 10 different kinds of the 194 bulbs.
dennis7222 is offline   Reply With Quote
Old 07-12-2016, 04:29 PM   #9
AnotherWs6
AnotherWs6's Avatar
Yeah, 6 bucks a piece though. Ouch, gotta pass on that.
Old 07-13-2016, 03:08 AM   #10
mcmlxix
Collector of Projects
mcmlxix's Avatar
On my old cluster setup I used red LEDs but I also disassembled the cluster and painted the inside gloss white to cover the mint green factory color.
I used ebay LEDs that had multiple diodes pointing in different directions to disperse the light in all directions....
Rich
1972 K5 Blazer CST Click HERE
Old 07-13-2016, 05:58 AM   #11
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
If you do this mod will the lights dim with the rheostat?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 07-13-2016, 06:17 AM   #12
mcmlxix
mcmlxix's Avatar
No. It's either on or off with the LEDs.
You can add a PWM (Pulse Width Modulator) to dim the LEDs but opted not to.
Rich
Old 07-13-2016, 09:32 AM   #13
AnotherWs6
AnotherWs6's Avatar
ochre1971 said that his dimmed somewhat. My understanding is that they need to be equipped with some type of diode - some are and some aren't. Could be wrong. A lot of the adds are straight from China and mention that they have a diode vs cheaper ones that do not.
I ordered two sets....
Green and yellow. I'll let you know how things turn out.
Old 07-13-2016, 10:03 AM   #14
ochre1971
ochre1971's Avatar
To add to mcmlxix's comment about the PWM, this seems to be what you need in order to make them "fully" dimmable. It's a stand alone dimmer specifically for this application, so you'd have to mount it somewhere accessible.
https://www.amazon.com/Auto-Meter-91.../dp/B000N8GIYG
Old 07-13-2016, 06:22 PM   #15
JJH Jimmy
JJH Jimmy's Avatar
Why not just put 168 bulbs in? They are 3 watt and the 194's are 2 watt. This is what I did and my cluster is bright enough.��
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 07-14-2016, 04:10 PM   #16
AnotherWs6
AnotherWs6's Avatar
Thanks - that may end up happening. I was hoping that we would get some good, specific info on dash lighting. All I could find was a guy used leds from somehwere, another from another place he cant rememeber, some used bigger bulbs. We need a FAQ about this.
Old 07-14-2016, 06:23 PM   #17
Ewr101
Ewr101's Avatar
They're dash light bulbs! There's 2 kinds, incandescents 168 and 194 or LED. LED's can't dim without a special LED dimmer. They come in different colors. A vendor was given- Super brightness.com and the rest can be had at Amazon or your local auto parts store. What more do you need to know?
72 Chevy 2WD Blazer
Ewr101 is offline   Reply With Quote
Old 07-15-2016, 11:26 AM   #18
AnotherWs6
AnotherWs6's Avatar
UUUUUUUUUUUUUUUUUUUUUUUUUUUUUM..... which ones - specifically - people have had good luck with.
