Old 01-20-2016, 09:16 PM   #1
chevytruckguy70
72 c20 engine compartment wiring question
I'm in the process of putting my truck back together and am having issues with lights (imagine that). I have gm shop manuals with wiring diagrams but they are for a 70 truck. I would have thought they'd be the same for 72 but I noticed my front side marker lights aren't wired like the diagram. They do not have a wire that goes to ground but rather goes back to the steering column. I'm guessing maybe in 72 the marker lights blinked with the turn signal?
It looks as though the 70 circuit is designed so that the side marker provides the ground for the front parking/turn signal lamps. I do not seem to have a good ground with my current setup and am wondering where the ground should come from.
I replaced my steering column with a tilt which adds questions to the issue as well. What's the best way to ensure that is grounded?
Thanks for any help.
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI.
2007 Chevy 2500HD 4x4 Duramax
1970 Chevy K20 (SOLD)
1972 Chevy C15 (1/2 C10, 1/2 c20)
1970 Chevy C10 (parting out)
chevytruckguy70 is offline   Reply With Quote
Old 01-20-2016, 09:44 PM   #2
kwmech
Re: 72 c20 engine compartment wiring question
Hook up the ground wire on the side marker to the turn sig circuit for the fronts. The blue wires if I remember correctly. When the signal is activated, the lamps will wig wag. Do it on all my trucks even my 68 that didn't have side marker lamps originally. No you can't do it on the rear.
Old 01-21-2016, 12:20 PM   #3
chevytruckguy70
Thanks KWMECH, I'll do just that.
