Old 01-20-2016, 11:20 PM   #1
deadshort52
Help with 2500 Hd wheels
I am going to use some 2500 HD aluminum wheels on my C20 camper special. I thought I had this all figured out but I ran into an issue. My rear axle protrudes out to far to allow the use of the shallow factory center caps so I obtained two dually deep style center caps. Now the problem is that the dually caps are to big around at the base to mate up with the rim properly. in other words the cap doesn't quite reach the lug nuts so I cant anchor it. What do I need to do? is there another cap that I need to be looking for? Should I be looking at cutting down the caps? Longer wheel studs??? Please help.
Here are a few pictures to help clarify things.
deadshort52 is offline   Reply With Quote
Old 01-20-2016, 11:34 PM   #2
Barnfind46
Barnfind46's Avatar
Re: Help with 2500 Hd wheels
I have those wheels on my 68'.I had no problems with the way they fit.Don't know if the rear end in the later trucks is different where the cap mounts and would cause interference or not. I will look at mine a little closer tomorrow.Name:  041.jpg
Barnfind46 is offline   Reply With Quote
Old 01-20-2016, 11:49 PM   #3
deadshort52
Originally Posted by Barnfind46 View Post
I have those wheels on my 68'.I had no problems with the way they fit.Don't know if the rear end in the later trucks is different where the cap mounts and would cause interference or not. I will look at mine a little closer tomorrow.Attachment 1490114
Attachment 1490115
I don't have any issues with the rear end clearance because I am using the dually caps which are deep enough. The issue is that the cap seems to big around to fit into the wheel properly. The diameter of the dually cap is about a 1/4" bigger than the standard shallow cap? I have the shallow caps installed on the front and they work fine.
Old 01-21-2016, 12:25 AM   #4
swamp rat
swamp rat's Avatar
May be the difference from a full floating Eaton and a Dana 60?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-21-2016, 12:34 AM   #5
deadshort52
Perhaps I should simplify things further. The caps will not fit into the wheel properly even if I don't have them mounted on the truck. I am thinking there must be another cap available.
Old 01-21-2016, 07:58 AM   #6
BigBlockBurris
BigBlockBurris's Avatar
I can't speak for why your caps won't fit off the truck, but like everyone else said, it is because you have a Dana 60 rear, right?
My truck below had a factory Dana 60 rear and the center caps would not fit. The FF hub sticks out further on the 60 than on the Eaton. I swapped a late model 14 bolt in mine and everything went together.
Hope this helps.
And those center caps aren't held on too secure with those cheap plastic lug nuts in my opinion!
Barnfind- Nice truck!!! I like it!!!
BBB
BigBlockBurris is offline   Reply With Quote
Old 01-21-2016, 08:21 AM   #7
deadshort52
Hope this helps.
BBB
I do have the Dana 60.
Old 01-21-2016, 08:53 AM   #8
BigBlockBurris
That's the reason the caps won't fit depth wise, you have a Dana 60.
I suspect that the reason the dually caps won't fit, is because the dually wheels are entirely different and must have a greater dish around the lug nuts.
Your truck appears to also be factory rear leaf springs, just like mine.
What is yours geared? Mine was 4.56, and that is the reason for the 14 bolt swap. To get some more highway friendly gearing.
FYI and you may already know this. A late model (73-up) 14 bolt is almost a direct bolt in. You just have to move one shock mount and get longer e-brake cables.
I really like your truck, I'm kinda partial to the 3/4 tons! HAHA!!!
Got any pics of the whole truck?
BBB
Old 01-21-2016, 09:07 AM   #9
deadshort52
BBB
I know that's why the caps wont fit. I researched this all over this board before I had the wheels powder coated. I learned that I needed the taller caps to clear the Dana 60 rear end. That is why I have the taller caps. It just seems like something must be different with my set up because other guys make no mention of having issues getting the caps to fit the wheels properly (not referring to the axle clearance now). The only way I see this working out is if I space out the rear wheels far enough to use the shallow caps or I cut part of the base off of the tall caps.
Does anyone know if GM caps are different between the steel and aluminum wheels on a dually?
My truck has factory coils. I am in the process of putting in a 700r4 transmission. Hopefully I don't have to change rear ends after the trans is done.
I will post some pictures later.
Old 01-21-2016, 09:17 AM   #10
BigBlockBurris
I think I have a set of the deep caps at the shop that are different than yours.
I will look and see and see if they will mount up. Maybe an option for you.
Wow, a coil spring Dana truck. I believe those are quite uncommon. I had a 68 coil spring 3/4 truck many years ago. it was an Eaton rear, but I swapped a 14 bolt in it too. A little more involved than on a leaf spring truck, but still easily doable. I drove that truck for many years, and it sure did ride better than my leaf spring I have now.
BBB
Old 01-21-2016, 10:05 AM   #11
deadshort52
BBB
That would be great if you could give me some insight on the caps you have. The shallow caps measure about 7 7/8" across the bottom and the deep ones measure about 8 1/2".
Old 01-21-2016, 10:18 PM   #12
Mike C
Mike C's Avatar
I ordered spacers for my '86 dually K30 and they had to made. They have a different pilot diameter than the 88 and up dually trucks where you can get spacers on eBay. The square body dually's through '91 should have right pilot. I think. You might see if there is a bolt on cap solution for them since GM went to the bolt on cap somewhere back then.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-22-2016, 07:01 AM   #13
davem815
davem815's Avatar
Deadshort52, I can't help you. But I have a dana 60 and used to have those tims on a 2003 GMC HD1500. I have never seen them painted white. I like that look. Reminds me of the white steel, but fancier. Can you post a picture of the front wheel with chrome cap on? I would like to see the finished look.
1966 GMC 1500 (3/4 ton) Custom V6 3sp Edna
1970 GMC C2500 Deluxe lwb 307/4sp Ol' Green
1971 Chevy C20 Custom lwb 307/3OTT, now a project in family since 1974
2014 GMC K2500 Crewcab 6.0 gas
2005 GMC Canyon Ext cab 4wd daily driver
1963 F*rd/Howe C750 fire truck 11,000 miles
davem815 is offline   Reply With Quote
Old 01-22-2016, 08:56 AM   #14
1968aj
I had the same problem. I took my sawzall and cut about 1/4 inch off the back edge of the caps. this allowed them to bolt on. when installed you cannot tell they are cut.
1968aj is offline   Reply With Quote
Old 01-22-2016, 11:27 AM   #15
Skinny Kid
I was just thinking the other day of powdercoating a set of those white for my C20. I like the look, but I have a Dana as well so I'll have the same issue.
1971 Chevy Custom Camper/20, Hugger Orange with White Top
31,000 original miles (when purchased), 402, TH400, PS, PB, AC
As of May 2017 it now has a turbo LS in it! (Still looks stock though)
Skinny Kid is offline   Reply With Quote
Old 01-22-2016, 04:58 PM   #16
sleepertruck72
sleepertruck72's Avatar
Those wheels look nice in white I have a Dana 60 with Dually caps on it. First pic should be the front wheel..second pic is rear wheel... Had to trim them to fit...
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 01-23-2016, 12:21 AM   #17
deadshort52
Here are some pictures.
I am going to fire up the Dremel tool and the belt sander tomorrow to get the caps to fit. If that fails I am going to order some spacers to move the rear wheels out so I can use the shallow caps like the front ones.
I really like the stock look with the white steel wheels and the hubcaps but my hubcaps are bad and I am sick of looking for a good set. I decided to powder coat a set of these and leave the caps chrome and paint the bowtie emblem blue for the older look. What do you guys think? Thumbs up or thumbs down?
Old 01-23-2016, 12:44 AM   #18
FirstOwner69
FirstOwner69's Avatar
I like the spacer idea for the rear. Shouldn't have to be too thick, but from your pics I think you'd need longer studs.
Here are the same caps on my Hummer wheels modified to mimic the original hubcaps.
FirstOwner69 is offline   Reply With Quote
Old 01-23-2016, 11:20 AM   #19
deadshort52
Is that a decal or a painted bowtie symbol?
Old 01-23-2016, 01:06 PM   #20
midniteblues
midniteblues's Avatar
i really like those wheels and they look great white.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-23-2016, 03:04 PM   #21
Joesjunk
Joesjunk's Avatar
I believe there are 2 different caps, ones for the steel wheels and ones for the aluminum wheels. Only a slight difference where they fit to the wheel. I bet you have a set for the steel wheels. Check that out and see.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 01-23-2016, 03:09 PM   #22
davepl
davepl's Avatar
Wish I'd seen this thread earlier! I did the same thing with those same center caps on my own Dana 60.
I went the spacer route. I think wheel adapters are bad mojo but spacers are OK. I forget if I wound up needing one or both, but I ordered 4 half-inch ones off eBay (I think). I figure 8 bolts is plenty in double-shear.
Anyhow, solved it for me. I have mine where the cap is still right up against the hub, it's tight.
This also serves to broaden the rear track and make it closer to the front, which is inexplicably wider on these trucks.
Depending on your studs and spacers, you might need new studs. I had to lengthen mine to get proper engagement. I also drilled mine out and replaced them with 9/16" to match the '72 fronts I installed, so if they look a little bigger, that's why.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-23-2016, 04:36 PM   #23
FirstOwner69
See post 255 in this thread for details on the cap modification. Additional pics in post 250
http://67-72chevytrucks.com/vboard/s...330740&page=11
Be aware that the 1997-2003 Malibu bowtie alone is not large enough to cover the gold bowtie on the caps. These Malibus are very plentiful in the junkyard near me.
My truck has an Eaton rear end, and the caps fit fine. As Joesjunk said in post 21 above, the steel wheel caps do not quite seat properly on the 2500HD alloy wheels, but I don't believe that alone would affect the fitment problem with the Dana axle. The alloy wheel caps have bulges/bumps around the circumference at the lug nut locations that are also visible in post 255 in the link above, whereas the steel wheel caps are smooth around the circumference.
Old 01-23-2016, 07:45 PM   #24
57taskforce
All about them K’s
57taskforce's Avatar
This is 100% true. I went thru this when swapping from gmc caps to Chevy caps on my brother in laws 06 2500hd. We got a cheap set of OE Chevy caps from Craigslist and fought and fought with them. I finally got to comparing part numbers and there are 2 indeed different caps. I'm sure a belt sander would probably fix the issue pretty easy.
Tyler
57taskforce is online now   Reply With Quote
