Old 01-21-2016, 06:34 PM   #1
clemsonteg
Power steering pump fitting
I read that I can use the sae fitting on the back of an older pump on the LS pump to adapt my lines to the LS pump. Can this fitting be purchased somewhere? I'm not having a ton of luck finding it and I no longer have my old ps pump.
clemsonteg is offline   Reply With Quote
Old 01-21-2016, 08:51 PM   #2
clemsonteg
Re: Power steering pump fitting
Found this http://www.speedwaymotors.com/O-Ring...ter,24682.html might be what I'm looking for if I can't find the fitting from an older pump
Old 01-21-2016, 11:08 PM   #3
Dustytrix
Following.
Dustytrix is offline   Reply With Quote
Old 01-22-2016, 08:01 AM   #4
truckdude239
truckdude239's Avatar
I went and got mine from the junkyard they chargerd me like a bux for it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-22-2016, 01:58 PM   #5
BilletSpeed
Subscribed. With my engine location, I just tweaked the return hose (the one made into pump tank) slightly to clear frame rail. I'm curious to see what others have done for the pressure line.
BilletSpeed is offline   Reply With Quote
Old 01-23-2016, 08:42 PM   #6
crazy longhorn
Fabricate till you "puke"
I have an 84 Burb box on my 69 (o ring fittings)....the hose screwed right into the LS pump. Yes, I did have to tweek the return line , as above mentioned, just a bit, to clear the frame rail. if you find the early flare fit nut, it will screw right into the LS pump ......longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-24-2016, 12:22 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Power steering pump fitting
Yes the fitting will screw right in. Mine did anyway!
http://67-72chevytrucks.com/vboard/s...d.php?t=627585
Link for new SS hoses.
http://67-72chevytrucks.com/vboard/s...hp?t=545846You
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-24-2016, 12:24 PM   #8
mattcrp1
mattcrp1's Avatar
I used an old 70's pump fitting on my 2002 4.8l truck p/s pump. I had a hard time finding one as well.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 01-24-2016, 12:26 PM   #9
clemsonteg
Did you find a new one somewhere or just get a new one from a salvage yard?
Old 01-24-2016, 01:25 PM   #10
engairuph
I used the fitting out a 75 chevy pump and put in my Ls pump. Andy4639 is the Upstate Gm truck club accepting new Members? Nothing on there site to join and I'm in Greenville for awhile.
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 01-24-2016, 01:43 PM   #11
clemsonteg
Always accepting new members. Check out the FB page. That's where most of the activity is https://m.facebook.com/groups/517668...?ref=bookmarks
Old 01-24-2016, 07:18 PM   #12
68basket
that should work
68basket is offline   Reply With Quote
Old 01-25-2016, 11:58 PM   #13
1bad396ss
I used the Speedway adapter linked in the previous thread and a set of stock style lines for a 72 with small block. Screwed right into the LS pump and sealed fine with the O-ring to flare adapter.
1bad396ss is offline   Reply With Quote
Old 01-26-2016, 08:03 AM   #14
Andy4639
Old member
Andy4639's Avatar
Member ship is free just need to contact Matt are one of the others to get you on it. It's open to all people as long as you like and promote the GM brand of trucks!
Get in touch with Matt he is on here also.
Username
MattPSU
Old 01-26-2016, 08:09 AM   #15
Andy4639
Old member
Andy4639's Avatar
Here is a link for some gm fittings.
https://www.google.com/#q=power+stee...valve&tbm=shop
Old 01-26-2016, 10:34 AM   #16
clemsonteg
Thanks Andy. I found several of the flow reducing valves for rack and pinion setups, but I haven't seen anything in stock form. I wasn't sure if the reduction from 3 to 2 gpm would be a problem on a factory gearbox.
