Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 01-21-2016, 09:39 PM   #1
Glenns66
Suburban bed ideas?
Hi guys
I'm looking to replace the wood bed in my 66 suburban.
I would like to know what others are using instead of the traditional 3/4 plywood?
Could I replace it with the wood boards and metal straps that you find in the beds of trucks?
Thank you for your feedback
Glenns66 is offline   Reply With Quote
Old 01-21-2016, 09:49 PM   #2
sk8er32283
Re: Suburban bed ideas?
I do not have enough expertise to be certain but I think that the bed from a truck would be to flimsy and the mounting would probably be a nightmare.
Based on your post, it seems as though you are going to leave it uncovered. You may consider still using the 3/4 plywood, but do a wood veneer on top of it. Another possibility is to do the 3/4 plywood, but get someone to do some mill work that would leave you will grooves to mount the bed strips into. This would give you the best of both worlds.
1971 Chevrolet C10(78 motor), Longbed, 69 Bed I think
Quadrajet 4 barrel 7043208, Th350 tranny, No A/C
Various components are lightly to highly modified depending on the number of beers consumed prior to modifications performed.
sk8er32283 is offline   Reply With Quote
Old 01-21-2016, 09:55 PM   #3
Glenns66
Good info. I think I could put extra metal support underneath the bed to strengthen up the structure. You may be right though, I'm on the fence. Maybe I sould just keep it simple.
Old 01-22-2016, 07:02 AM   #4
64k10burb
64k10burb's Avatar
I have not looked that close yet either, but I agree that simple is good!
If I were going for a nice wooden floor look, I would stick with 3/4 ply and add 1/4 hardwood ply (can be had in red oak white oak,walnut,etc.) cut into strips and machined to accept the metal strips. That should give a very similar look without too much hassle.
Things to consider are gas tank, brake/fuel lines, and cross-member locations for accessibility/damage while drilling/bolting the strips.
Brian
1969 c-10 short/wide/6L LS swap
1964 k10 suburban project
1964 Falcon sedan delivery rescue project
64k10burb is offline   Reply With Quote
Old 01-22-2016, 09:51 AM   #5
Glenns66
Great reply that might be my opinion!
Old 01-25-2016, 06:45 PM   #6
notsolo
notsolo's Avatar
This 1 turned out very nice, 4th photo from the bottom... I think he put a 1/4" hardwood ply over 3/4 ply,... you would have to Pm him about his build.http://67-72chevytrucks.com/vboard/a...p?albumid=1992
notsolo is offline   Reply With Quote
Old 01-26-2016, 04:10 PM   #7
Brad54
Brad54's Avatar
Panel trucks came with wood planks like a pick-up bed, so it probably wouldn't be too difficult to replicate that.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 01-26-2016, 04:54 PM   #8
Glenns66
