01-22-2016, 06:30 AM | #1 |
Need advice on upgrades. Brakes,suspension,bags???
So I have been mowing over what to do with a little extra cash I have from selling a motorcycle I built,I have about 2k to blow on my 64. At first I was just going to do a static drop with full disc all the way around from either performance on line, or CPP. I then thought about just doing front and upgrading some other components such as control arms, sway bars, or trailing arms Etc. Then the overwhelming desire to put my truck on the frame came to me and I started looking into bags. So I then started looking into doing a disc conversion in the front and putting a simple bag system on and cupping my LCA's. But then the thought came to me maybe just put in a nice bags suspension system and putting discs on later. So with all that thinking going on I am all thought out and don't know what I want to do. So this is were I need everyone's opinions (as I know everyone has one).
A. Full power disc with sway bars front and back. B. Front power disc and updated control arms and trailing arms etc.. C. Front power disc and simple air kit with cupped lower control arm. D. Nicer bag system and update the breaks later. E. something I haven't thought of. If I did C I would do one from way2lo2 or from EZ Air Ride. The truck is not show quality and will not be for quite some time. But I'd rather do it right the first time and not have to upgrade my system later. Any advice would be great and links are helpful. Thanks as always this site rocks............... |
01-22-2016, 11:17 AM | #2 |
Re: Need advice on upgrades. Breaks,suspension,baggs???
Well you said put the truck on the frame and that won't happen with the plans you have. If you ment just put it on air and get it way down it will work. First thing I would do is the brakes with the upgrade to power and disc in the front. Put on all new brake lines and get it 100%. Then I would get a paddle valve setup from Travis with all the plates, bags, shocks, notch, lines, long panhard bar, tank, compressor and associated hardware and see where you are with you budget. You still may need wheels and tires to work with the disc and the drop you will get from air. You may find your 2K runs out pretty quick.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-22-2016, 12:28 PM | #3 | |
Posted via Mobile Device |
01-22-2016, 12:44 PM | #4 |
Stalker Nate
$2g doesn't go far when talking about doing it right & an airbag setup. I wouldn't cheap out on the airbags either. In the same boat here, we'll be rebuilding our brake system first, 12" discs front & back as we're on 20/22s. Then if there's money left over, start on the full bag kit.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
01-22-2016, 07:14 PM | #5 |
The limiting factor with the 20's is the height of the tire. With the 20" wheels on my 65 the top of the fenders sat on the tires so the sheet metal was holding the truck up. I did not like the idea and went to a 15" smoothy wheel and a smaller height tire. Now the cross member sits on the ground and the tires are not hitting the inner fenders. I could see the sheet metal move when it landed on the tires. The truck also sets a good bit lower when aired out.
Jimmy
