Old 01-22-2016, 10:28 AM   #1
enduroride
enduroride's Avatar
72 grille install help
Purchased a new grille, new hardware kit, and new grille support brace from LMC Truck. Problem is the truck was not together when we bought it so I'm having to figure this stuff out by looking at pics and parts schematics. I have the actuall grille in, but can't figure out what hardware to use to connect the grille to the support bracket. Need to know what screw and clips go were and from which direction .
Up close pics would be great if anyone has any available
Thanks in advance
2016 Silverado2005 GMC Sierra
2002 Chevy Slverado Extra Cab (youngest sons)
2009 GMC Denali (oldest sons)
2015 Lexus 250i (wifes)
1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY"
http://www.louisianaclassictruckclub.com
enduroride is offline   Reply With Quote
Old 01-25-2016, 07:47 PM   #2
enduroride
enduroride's Avatar
Re: 72 grille install help
Bump
Old 01-25-2016, 08:18 PM   #3
Phildeez
Phildeez's Avatar
I just had mine apart. On mine the square inserts went through from the radiator side sandwiching the grill insert. Then used a small sheet metal type screw to expand the square piece. Like a drywall anchor. Hope this makes sense. I'll post a pic in a few.
Phildeez is offline   Reply With Quote
Old 01-28-2016, 10:09 AM   #4
jmillsUT28
TTT will be having this same problems. If anyone has any pics please post them. Thanks!
jmillsUT28 is offline   Reply With Quote
Old 01-28-2016, 01:02 PM   #5
kx57
I can see if I have any pictures of a grille installed shortly.
In the interim. I might as well post this to see if it helps:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
kx57 is offline   Reply With Quote
Old 01-28-2016, 01:39 PM   #6
kx57
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG]IMG]http://i63.tinypic.com/2q32fyw.jpg[/IMG][/IMG]
This is off one of our dead trucks we haven't restored....my understanding is it was still factory on the front end...never been taken apart.
Take that with a grain of salt...as I'm not 100% on that.
Old 01-28-2016, 05:17 PM   #7
In The Ten Ring
I have a ton of pictures but I cannot upload any until I take my computer in to the shop and they straighten it out. I managed to get one of like 25 pics that I have on this thread.
The inner grill to outer grill and back to the front of the truck is pretty easy.
The inner grill is held to the outer grill (I have a 1972 truck also) with a series of square "clips." You might can buy new ones at an auto supply store, I used my old ones. These push in. There is a small screw that also goes into the clips but I don't see what purpose those fill.
The outer grill is riveted to the grill brackets, I screwed mine together with little pieces a member suggested, forgot what those are called. Found a pic! Ebay.com has these "rivet screws" or something. I forgot what size I bought.
http://i.ebayimg.com/06/!B9mv+gQCWk~$(KGrHqEOKjsEzFffEK6BBM6U0k2T0!~~_35.JPG?set_id=8800005007
The grill brackets bolt to the outer fenders. You can sorta see where those go in this pic.....the computer just won't let me link the other pics I have on this.
Just can't upload what I have, sorry.
In The Ten Ring is offline   Reply With Quote
Old 02-17-2016, 08:35 AM   #8
enduroride
enduroride's Avatar
thanks for the pics guys.....I have the inner grille in place, found out the problem was the PO had the wrong hood latch bolted to the core support, it was throwing everything off ! Ordering the correct hood latch and everything SHOULD line up !
Thanks for the help and the pics
Wade
Old 02-17-2016, 04:19 PM   #9
sawyerrm
sawyerrm's Avatar
Want to do this too, gotta find a grill first
http://67-72chevytrucks.com/vboard/s...ighlight=grill
Rob
sawyerrm is offline   Reply With Quote
Old 04-05-2016, 10:25 AM   #10
Hart_Rod
Hart_Rod's Avatar
Great thread!
Hart_Rod is offline   Reply With Quote
