Old 01-22-2016, 04:29 PM   #1
68 CRACKERBOX
68 CRACKERBOX's Avatar
swap to auto from std behind v6
can anybody tell me what all is needed to go from a std trans to a 700r trans in a 63 gmc 2500 with a 305 V6? I know need a steering col. , but will the trans bolt to the V6 and does it take a diff. flywheel than a V8?
short bed are just cars without trunk lids
trucks have long beds
real trucks are longhorn
72 gmc 2500 longhorn
68 chevy c-30 50th anniv. 9ft step side
68 gmc crackerbox 8v71 detroit
72 gmc astro95 8v71 detroit
68 CRACKERBOX is offline   Reply With Quote
Old 01-22-2016, 05:13 PM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: swap to auto from std behind v6
I'd ask here as well: http://6066gmcclub.com/forum/index.php
These guys know these engines in their sleep. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-22-2016, 05:34 PM   #3
jbgroby
jbgroby's Avatar
I have a 4 spd. hydra-matic, You will need this adaptor plate to mate an automatic. Benson Transmission adaptors has all the modern parts you need.
http://www.transmissionadapters.com/...%20&%20V12.htm
jbgroby is offline   Reply With Quote
Old 01-22-2016, 08:39 PM   #4
padresag
this fellow can fix you up with what you need, he is in s/ca.
paidavidinha@live.com
ron
padresag is offline   Reply With Quote
Old 01-23-2016, 11:48 AM   #5
Dans1960SWB
Is that a four speed Hyrdo Transmission? WOW what a monster!!!
Dans1960SWB is offline   Reply With Quote
Old 01-23-2016, 12:00 PM   #6
padresag
there is no such thing as a hydro transmission.
ron
Old 01-23-2016, 12:12 PM   #7
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
ron
Hydro being the shortened version of Hydromatic. lol
Old 01-23-2016, 12:23 PM   #8
akaupp
B&M modified the Hydramatic and called them Hydro Stick.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline   Reply With Quote
Old 01-23-2016, 01:26 PM   #9
padresag
some people are just like little sheep; one jumps over the cliff and the rest follow. Remember what I said about spending more time with the books at school., if you are going to correct someone you should be sure of the correction."hydramatic" is the trademark of an a/trans developed and manufactured by GM.
https://en.wikipedia.org/wiki/Hydramatic
ron
Old 01-23-2016, 01:46 PM   #10
jbgroby
jbgroby's Avatar
Yep, she weighs in at about 110 pounds. And has 36 bolts to mate up to the flywheel. You need to have smallish hands to fit into the access plate (small square opening on top). The best part is you cant mount the flywheel wrong. The geniuses at GMC created a evenly balanced flywheel that you could mount to the crank.in any position. In addition to that, the flywheel is a solid casting.
Old 01-23-2016, 03:15 PM   #11
cv65
cv65's Avatar
ron
Im 65 and raced a few "Hydros" in my time,maybe this will help you out.
http://www.hotrodsandclassics.net/hotrodslang.htm
cv65 is offline   Reply With Quote
Old 01-23-2016, 03:40 PM   #12
padresag
glad that you are 65, hope that you make it to my age.
looked at your link and here is the exert from it. some dumbo even spelled it it wrong there,"Hydro: Automatic transmission ( derived from the name Hydromatic, a GM transmission used in the 50's"
GM made a Hydramatic trans. B & M made have called their adaption a hydro-stick but it was still using a Hydramatic trans by GM. it is a copyrighted name.
I have also had 4 vehicles with hydamatics in them and also worked on them at my place of employment in the 60's
ron
