01-22-2016, 05:07 PM | #1 |
removing sprayed on bedliner??
My truck has spray on bed liner, and its very sprayed on heavy. They went all the way to the top of the bed. I want to remove the coating from the top lip of the bed rail, and hopefully save the paint underneath.
In my searches in have found that heat seams to be the best option. I'm thinking of trying a heat gun and seeing if it will cause a reverse reaction. Any idea's or experience? Thanks Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
01-22-2016, 08:38 PM | #2 |
Re: removing sprayed on bedliner??
I got news for you . If it was a professionally spayed job there is no saving the paint . They use about a 40 grit sand paper or something like it on the paint to scuff it to make it stick . I dont think you are going to like what you find under there .
01-22-2016, 11:00 PM | #3 |
Post Whore
Don't ask me how I know but pvc glue will remove sprayed on bedliner
01-23-2016, 12:29 AM | #4 |
I was hoping I wouldn't have to paint the whole truck right now. The paint is cleaning up really good. And with a little buffing the shine is coming right back. Most of all the stuff on the truck is Water Oak Sap. When I bought the truck it had been sitting under a couple of those mammoth Oak trees.
I have never been a fan of spray in bed liner. I have been know to wax the inside of my bed before, I always keep it washed and clean. Thanks for the responses Ken
01-23-2016, 08:13 AM | #5 |
Do you know what brand bedliner it has in it?
