Back –up light ?
Were is the back-up light switch located on a 67 C-20 with 3 on the tree?
Thanks in advance.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I think they are located on the tranny and not the colum..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
That’s were I always thought it was but pulled the trans. last night there was no wire which has left me a bit perplexed.
I’m going to a th-400 and floor shift and didn’t want to cut in to the harness going back to the lights.
Inline 69
follow your harness from the fuse box up across the top of your engine comparntment,theyre will be a lt green & a drk green wire that are moulded together,at some point they will drop to the top of your tranny from the main harness,,,,,,thats for your reverse lights,,jeff
Nope no wires and no switch on the trans.
Inline 69
you didnt find those dk green & lt green wires in the harness along the top of the engine compartment ??
Nope none there.
There is Starter sol. Wire Oil press. Wire Power wire for ignition 12v start for ignition
Do the wires drop down on the diverside or the passengers side i have a few wiers that did not get hooked back up after the engine install and the back up lights dont work that is the only thing that i can think of but cant fide a place on the tranny to hook them up to
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
Yeh It's Fast
my switch was located on the column right before it went thru the firewall on top of the column (1971 3/4 C20)
HOPE IT WAS OF ANY HELP |
Resident Curmudgeon
![]() Join Date: Dec 1999
Yup, on the base of column before it passed thru the firewall. If your switch is missing you should still have the wires coming off the fusebox harness. I think they are the green color mentioned before
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
