Old 01-22-2016, 07:14 PM   #1
SGJ72
SGJ72's Avatar
quick backspacing question
thinking about putting some 15x8 Rallys on my 72, but these wheels have a 4.5" backspace. as I understand, that's so they can tuck under better, yes? so I can run a taller tire? I haven't lowered the truck any yet, and may not get to that for a while. so, running this backspace, it's not going to make the truck look weird, is it? like, too narrow a track? if so, I could run down some 15x8 Rallys with no backspace, probably.
I searched all through here for an answer to this, and probably read it sixteen times, but I wanted to be sure before I do it. thanks for any help.
no build thread, but I could probably rig together a bill-thread
SGJ72 is offline   Reply With Quote
Old 01-22-2016, 07:56 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: quick backspacing question
Are you sure they are 4.5" backspace?
(pics?)
If so they will rub on your tierod
4" is usually the max backspace on a 15" diameter wheel up front.
Keith
Convert to disc brakes.
Old 01-22-2016, 08:02 PM   #3
SGJ72
SGJ72's Avatar
man, don't want that rubbing action. hadn't even considered that. thanks. and, don't have them yet, was only considering them:
https://cosprings.craigslist.org/wto/5409519546.html
Old 01-22-2016, 08:41 PM   #4
lolife99
lolife99's Avatar
Those are 15x8 truck rally wheels.
They have a 4" backspace.
NOT 4.5"
Keith
Old 01-22-2016, 09:53 PM   #5
SGJ72
SGJ72's Avatar
good to know, thanks. so, he's got the specs in the listing wrong? I'm guessing if 4.5" will rub, though, then 4" might as well. may just wait till some with no offset show up, I guess.
Old 01-22-2016, 10:09 PM   #6
Kennuck
Kennuck's Avatar
An 8" wide rim with 4.0 backspacing is 0 Offset.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 01-22-2016, 10:18 PM   #7
SGJ72
SGJ72's Avatar
ah. so it's just a stock-normal rally rim, then? guess that wouldn't rub. cool. maybe I'll pick these up. thanks.
