Old 09-20-2003, 11:19 PM   #1
stan79chevy
stan79chevy's Avatar
conversion kit for 203 t case
has any one put in one of the conversoin kits for the 203 transfer case to make it part time. if so how hard was it. and what is the shift pattern. i have a 203 and only the manual hubs, so after a stuck i have to get out and lock them in. i would prefer to lock the hubs in first the shift form 2wd to 4wd after a stuck like a 205.
stan79chevy is offline   Reply With Quote
Old 09-22-2003, 02:05 PM   #2
smokekiki
Mike
smokekiki's Avatar
The 203 is full time unless it has been converted with a kit.It's not supposed to be good on it to run it with manual hubs unlocked.Are you running it in 4wd locked?Also your hubs should be locked and ready before you get stuck.I don't have the kit,I was also wondering how well they work.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 09-22-2003, 02:31 PM   #3
Mudder
Mudder's Avatar
I had one installed about 20 years ago in mine.........has taken a lot of abuse and never had any problem with it.
Mudder is offline   Reply With Quote
Old 09-22-2003, 03:28 PM   #4
smokekiki
Mike
smokekiki's Avatar
stan79chevy,go to www.coloradok5.com on their revue board there is a write up on the 203 conversion kit from milemarker.Thanks Mudder,I am looking at a 71 suburban that has a 203 put in it.
Old 09-22-2003, 05:36 PM   #5
hlm47
I have a 77 GMC with the 203 case. The milemarker kit is easy to instale. If you don't use a kit of this type, the transfer will still be in 4 wheel drive. There are parts in the transfer that have to be changed. As far as the shift pattern, it stayes the same.
I have made the change for more miles per gallan. It didn't make it any better. On a wet road it's hard to start out with spinning the tires, And it seemes that I'm allways to late to put it back in 4 wheel drive.
It is a good kit, but I my self will be putting mine back to full time.
It may help you and I am not trying to talk you or any one out of it.
Thank you,
hlm47
77 4X4 Chevy
52 Chevy truck 4x4 (bulding)
67 Camaro RS
hlm47 is offline   Reply With Quote
Old 09-23-2003, 08:35 AM   #6
trukkers69
If you decide to get conversion kit , and if I can find the darn thing .I've got a brand new MileMarker kit I'll let you have for $35 plus the ride. Jeff
EXPERIMENTAL STAGES OF SANITY
_____________________________
Run whatcha brung, and hope you brung enuff
trukkers69 is offline   Reply With Quote
Old 09-23-2003, 09:12 AM   #7
smokekiki
Mike
smokekiki's Avatar
Jeff,this is Stans thread,if he doesn't want the kit I will.
Old 09-23-2003, 10:33 AM   #8
alf4444
alf4444's Avatar
I jump in line next for the kit if everyone else passes!
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 09-23-2003, 02:31 PM   #9
stan79chevy
smokekiki
i checked the colorado k5 site and that is what i want. you can shift form 2wd to 4wd from in the truck.
trukkers69
where do you live
Old 09-23-2003, 08:49 PM   #10
trukkers69
I'm located in Central Mississippi
Old 09-25-2003, 09:42 AM   #11
stan79chevy
thats quite a drive
the napa near me has the kit with hubs for $95. i think ill get that one next week. are there any parts that i may need that arent in the kit?
Old 09-25-2003, 10:07 AM   #12
smokekiki
Mike
smokekiki's Avatar
I think on the k5 site it says you need some of the seals.Not sure which without rereading it.Thats a good price.JC whitney has them for 104plus shipping.
Old 09-25-2003, 07:26 PM   #13
trukkers69
You better buy it then .The kit I have cost me around 65 or 70 bucks , but thats been couple of years ago.
Smokekiki, your up
Old 09-25-2003, 10:13 PM   #14
smokekiki
Mike
smokekiki's Avatar
Let me know where and when.My zip is 19380.
