Old 09-20-2003, 11:24 PM   #1
stan79chevy
stan79chevy's Avatar
203 t case conversion kit???
i want to know if any of you have put this is your truck? and if it makes the case like a 205. so you can drive in 2wd then shift into 4wd after your stuck. also how hard it is to install, wheather or not you have to take it out of the truck or if you can do it while it is in the truck.
thanks
stan
stan79chevy is offline   Reply With Quote
Old 09-21-2003, 01:05 PM   #2
Jonboy
Slots go on anything!
I did mine out of the truck, but only because the trans and case were already out. The kit was pretty easy to put in as I remember. If I remember correctly, you can shift on the fly to the "LOC" (high or low) positions while moving. You do have to stop to move from high to low, though.
1974 Jimmy- 5.3/4L80e/NP241
Old 09-22-2003, 02:14 PM   #3
smokekiki
Mike
smokekiki's Avatar
What kit did you use?What did they say about lubrication?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 09-22-2003, 05:34 PM   #4
76bonanza
76bonanza's Avatar
I have a converted 203 and was told 10w40 is good and after you convert it about once a month I put it in 4 wheel loc but dont lock hubs to lubracate all the seals.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-22-2003, 06:44 PM   #5
smokekiki
Mike
smokekiki's Avatar
I read about the install on www.coloradok5.com Go to thier product review page.
