Happy to be here
![]() Join Date: Mar 2000
This is better....
I know it's not a "show truck" , but I can't stand dirty suspension peeking through big wheels. I had to clean it up some. Here's what it was like...
Happy to be here
Another view before...
Happy to be here
OK, now this is better. Considering I I didn't remove much, it came out pretty good. Next time I will pull it all apart, and repaint it....
Happy to be here
Here's another view. The drop light makes the color look gold, or pewter. It's actually gray...
world class smart ass!
Did you use the old touch up in a can? Looks damn good though!!
Aric 75 2WD BLAZER (never ending project) -some day maybe- 02 2500HD CREW CAB 4X (daily drive) -8" lift 37s and 22s- ____ ![]() |
Happy to be here
I didn't have any time left to do the rear suspension. It was 2:00 AM, and time to get some rest. I managed to paint the drum though...
damn you guys and your clean trucks!
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#8 | |
Happy to be here
[QUOTE]Originally posted by N2TRUX
[B] Yeah, I am the rattle can king. Well king, you got yourself some comp. cause my whole truck is krylon:p
Crap did I just admit that!!!!
Under construction!
Looks awesome, Ken!
2001 Silverado bagged on 22's. *Sold* |
Ken, are those stock A-arms, just modified to fit the bags? I didn't know you had Air-Over-Leaf in the back either...
#13 |
yeller
Looks great Ken...world of difference!
-Jeff |
#14 | |
Happy to be here
Yes, we decided to "try" keeping it simple, and forgo a 4-link. We removed all but two rear springs, used a bag over kit, and a set of 2" blocks... ![]() |
#15 | |
#16 |
I'm back with 2nd truck!
Damn Ken that's freaking beautiful. How much do you charge by the hour
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
#17 |
I'm w/Ken on his decision guys.... his truck rides very good as it sits w/the air-over-leaf set-up. No need in re-inventing the wheel, which the 4-link would have been in his case. Plus, there's much less work involved.
Also, Timspeed..... what exactly do you find so 'crazy' about using the stock a-arms? Looks great Ken. Good eye on the details.
#18 | |
Under construction!
![]() Air Lift and ART both make bolt-on kits designed for use with the stock LCA's. I'm keeping the stock control arms for the ease of rebuilding the front-end in the future. Chances are, it won't be easy finding correct bushings for custom control arms in 5+ years, as none to my knowledge, use factory style bushings. ![]()
#19 |
its just $$$$$
I have basicly the same set up on my blazer. It rides great and is definitely much easier to install. the work to benefit ratio seems a little out of porportion when it come to doing a 4 link on one of these trucks. BTW looks awesome Ken
#20 | |
Trucker.
#21 | |
Happy to be here
We decided on this truck to go with a simple set up, that didn't require a lot of fabrication. I was not impressed with the design of ART's 4 link on my Blazer. I tried to get Bill Carlton from Ekstensive Metal works to build a 4 bar system that didn't require a bridge for support. He said he would, but never did. The decision was made to keep it simple, and use a bolt in system. If this didn't work, all that is required to change to a 4 link is unbolt the bags and springs, and install a 4 link. It works well so it will stay for now. As far as the front goes, Im not sure why you consider stock A-arms as "a little jerry-rigged"? I agree that tubular A-arms look better, but what is wrong with the stock A-arms? Since I am running dropped spindles, I can't (or won't) combine spindles and dropped A-arms. That doesn't leave me with much choice... ![]() |
#22 | |
Happy to be here
#23 |
Village Idiot....
Should I be offended by the A-arm statement made by TIMSPEED
(IMHO, it seems a little jerry-rigged.) cause I am the one that installed the front bags on the truck. To make sure I'll ask my wife, she tells me all the time what I should think.... I better go and work on the bathroom now...... N2TRUX will explain..... |
#24 | |
Happy to be here
Get back to work Bathroom boy... ![]() |
#25 |
Yes, get back to work so you can come & work on mine (hers)....
