installing rear motor mounts
i am in the process of installing these rear motor mounts http://www.classicparts.com/1954-72-.../#.VqQNsFmYLlg the issue i am having is i cant get the bigger U shaped mount to fit into the hole. i have tried putting a bolt through the mount and compressing it down. but unbolted it and it just seemed to cut into the mount. any tips?
Re: installing rear motor mounts
The bigger piece goes between bell housing and cross member facing down. Small piece goes in the cross member bottom side . Bolt should go right in. Get both sides in before tightening in case you have to shift it a little.. Never seen those give a problem.
