Old 01-23-2016, 07:35 PM   #1
1960chevypanel
Anyone have a 3/4 ton 4x4 hubcap? Need measurements..
Anyone have an original 4WD cap? I need pics & diameter of the pilot hole.
1960chevypanel is offline   Reply With Quote
Old 01-23-2016, 07:58 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Anyone have a 3/4 ton 4x4 hubcap? Need measurements..
Saw this on youtube. While the parts book lists the inner dimension for the clip wheels it doesn't list the diameter for the axle tube hole.
https://www.youtube.com/watch?v=6pFk_CZJvnw
Old 01-25-2016, 06:50 PM   #3
60-66
60-66's Avatar
I measured my original 1960 3/4 ton 4x4 caps and come up with 4.970 . The one on the right I showed you before is .025 larger or 4.995 . Not sure if it "was" a Chevy or GMC cap originally but it has no signs of the Bowtie or GMC stamping. The factory edges just seem to be smoothed out.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-25-2016, 07:12 PM   #4
j.kirn
Thanks for those meausrements Jon.
j.kirn is offline   Reply With Quote
Old 01-25-2016, 08:02 PM   #5
1960chevypanel
Thanks Jon, I was going back through your messages yesterday trying to find that spec...
Do the edges of the hole look like they were cut and rolled, or just cut?
Are there any tool marks or other signs that the 61-63 cap is homemade?
Old 01-25-2016, 10:10 PM   #6
60-66
60-66's Avatar
They look just cut , like the NOS 1/2 ton you sent me. Once the hole was cut just smoothed out.
The 61-63 was cut after it looks like. Its an NOS cap but theres no paint on these edges and a scratch on the surface.
Old 01-26-2016, 03:26 PM   #7
1960chevypanel
Is the 61-63 1/2 ton cap opening about 3.675? That's what I got on my 57-60 1/2 ton caps.
Old 01-26-2016, 03:55 PM   #8
60-66
60-66's Avatar
Yes , thats basically what I get , just hair larger 3.690
Old 02-01-2016, 12:33 AM   #9
1960chevypanel
So it stands to reason that the hole size stayed the same over the years. Which is what I would have guessed since the hubs were the same.
Old 02-01-2016, 12:41 AM   #10
1960chevypanel
That 4.970 measurement works out to 4 and 31/32". Or basically a fingernail's difference on each side of the hub. So instead of tying myself in knots with that I'll just go with a 5" punch. The hub is exactly 4.5", so that will leave a neat quarter inch on each side of the cap opening. Which is the same gap the half tons have. Problem solved, although I'll still keep hunting for originals.
