Window regulator rebuild
I am installing my windows on my 79 c10. The regulator has a bad wheel on it. How do you pull that off and replace it? I have another regulator with the wheels but wrong shaft. So I want to pull a wheel off of that one and install on my original regulator. Thoughts?
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Post Whore
![]() Join Date: Aug 2014
Re: Window regulator rebuild
I just did that, check out my thread, and there is even a link in there to a YouTube video of another owner to help you out
http://67-72chevytrucks.com/vboard/s...45440&page=103 |
#3 | |
Is it even possible to pull the old ones off without breaking them? Looks like LMC sells them, but has the rivet with them. I could cut the old rivet off and add a bolt. would this work, just no sense on spending money if I already have one.
Post Whore
The old rivets are pretty easy to drill out but you will sacrifice them and if you put in new ones they would need to be riveted in I think, as there may not be enough room in the track for a screw/bolt head
Or I could just drill out the handle shaft and swap that out. Put my origninal on the other regulator and go that route. Not so much that I have to pay for one, just that I don't want to wait for the shipping Will see which is easier
I went trough this not long ago. Do not buy the lil wheel from LMC, they aren't a good fit. Grind the back side off the rivet and knock it out with a punch. Do the same on the other regulator and then spot weld the good rivet wheel back on. Use some WD-40 to clean out the wheel and tracks on the door, then spray in some white lithium grease into the wheel and tracks.
#8 | |
Im not sure about the cranks.
![]() Join Date: Jul 2000
Even if you can manage to replace the rollers, there's good chance your shaft mechanism is worn out. For $21 + $7 shipping, I bought a pretty nice regulator from Rock Auto for my 1982 truck.
I did have the same problem as Greg -- my OE window crank wouldn't slide fully on the new shaft. I ended up spending $6 on a Dorman replacement at my local auto parts store.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
The shaft mechanism seems tight. I am going with the welding plan as soon as I can convince my wife to let me back into the garage
#12 | |
I hope yours is fine, and I'm just trying to save you some time and effort. ![]()
#13 |
I know the pieces fit
I don't have a regulator here to look at but I'm wondering if that plastic wheel is going to warp or melt if you tack the rivet on the frame.
#14 |
That wheel is far enough away. Quick tacks will do the trick. Got the ok for garage night so will let you know
#15 |
Oh how nice it was to get the welder out tonight. Thanks for the tip
#17 |
Good work
