Old 01-24-2016, 02:15 PM   #1
Bigez209
Air bag kit
Just got a 1971 gmc super custom long bed. gonna cut the frame and bed to a short bed. But anyways I'm new to the air bag scene was looking for a semi cheap kit. Was looking at the kits on eBay for around 5-600. Was wondering if they wer decent kits. I'm not expecting anything crazy quality but something that works with out breaking the bank. The one I was looking at was 499.99 free shipping. Includes these in the kit. Thanks in advance and happy to finally be apart of the awesome forum.
4 2600 Airsprings. You can Upgrade to other sizes for $50
4 Bag Fittings
8 3/8" Brass 250psi Valves
4 Speed Controller Fittings
1 AVSX 7-Switch Controller
4 3/8" Air Fittings for Airbags. You can Upgrade Fittings & Airhose to 1/2" for $50
3 Gallon 8 Port Steel Tank. You can Upgrade to 3 Gallon, Polished Stainless or 5 Gallon options
4 Speed Control Valves to control the rate of lift
Pressure Switch 90on 120off to maintain tank pressure
2 DC480 Compressor with Steel Airhose and CheckValve installed.
2 40amp Relay with pre-wired Socket
1 Chassis Tech T-Shirt
Bigez209 is offline   Reply With Quote
Old 01-24-2016, 04:50 PM   #2
PGSigns
PGSigns's Avatar
Re: Air bag kit
First is your GMC a trailing arm truck or rear leafs. In the vendors section look up Pro Performance and get with Travis on what you want to do to get the right stuff for the truck you have.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-24-2016, 04:56 PM   #3
Benny-
Re: Air bag kit
I was just reading poor reviews on chassis tech. Might want to verify. Also, as with everything else, you get what you pay for. I'd rather buy stuff from a known vendor who sells quality parts
1972 C/10 Cheyenne, Daily Driver. SOLD
1978 GMC K15 High Sierra.
Benny- is offline   Reply With Quote
Old 01-24-2016, 05:15 PM   #4
Pro Performance
Pro Performance's Avatar
Re: Air bag kit
Thanks for the referral PGSigns.
It is easier to bag it if it's trailing arm suspension, but most GMC's are leaf spring. We can put together a bag kit for you around the $1,000 price. It will be using quality components that you'll trust under your truck. In the future, you can build from it, adding shock relocaters, adjustable trac bar, etc.... Which are all things you'll want to consider doing to make the suspension work well.
This is all considering it is a trailing arm truck. Even if it's not, we can still do a bag kit for you, but won't be as bolt-on and in the $1,000 range.
Give me a call Monday if you'd like and can go over more in detail.
480-420-8175
Travis
Pro Performance is offline   Reply With Quote
Old 01-24-2016, 10:16 PM   #5
bbbc10
Diggin The SquareLife
Re: Air bag kit
STAY away from chassis tech!! An stay from buying cheap air ride off ebay......
bbbc10 is offline   Reply With Quote
Old 01-25-2016, 02:37 AM   #6
dubds10
Stalker Nate
Re: Air bag kit
$500 will get you 4 quality airbags typically, but not a full kit that's good enough to last or that I'd trust my life with lol And if you're chopping a LWB to SWB please use a certified welder/experienced builder. Messing with frames & suspension can be very costly if done wrong the first time.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 01-25-2016, 02:56 AM   #7
andrewmp6
Re: Air bag kit
Yeah do not buy anything from chassis tech aka airbagit they are a joke,They make knock off airbags they won't list the specs on their air compressor.And a member a while back bought one of their air management kits one valve in it would leak.He called them for help they gave him the run around and basicly told him good luck fix it yourself.Honestly i would only buy off known vendors which are most of the forum vendors like Travis up there.He only carries the good brands he knows his stuff and prices are fair to me.
andrewmp6 is offline   Reply With Quote
Old 01-25-2016, 06:14 AM   #8
Bigez209
Re: Air bag kit
Ok thank you everybody for your responses. I will stay away from the eBay kits. My truck is equipped with the trailing arm suspension. My dad and I will be doing the work on shortening the frame. We have been working on cars for as long I can remember and my dad has been welding for a very long time as well. Just new to the air bag scene and was wondering about the kits. When I do get my money for the kit I will get in contact with one of the vendors. Thanks again for the quick responses. Glad I finally joined forum.
Old 01-25-2016, 09:14 AM   #9
andrewmp6
Re: Air bag kit
If you want just a basic bag kit those ain't too bad price,If you want it to lay frame things start to get really pricey.
