Old 09-21-2003, 02:31 AM   #1
GMC69
GMC69's Avatar
Unhappy Project hit a wall
Well I brought the truck back indoors ( where it was stored for the last 2 years) before what was left of Isabel came on Friday. I noticed that the roof had a crack ( figured it was bondo). I was right. It had to be almost 1/2" in some places and underneath it was dented really bad. So before I get going I know I need a new cab now. It also needed all 4 cab supports and new floor sections on the driver and passenger side, along with one cab corner and the kick panels.
Now since I know the cab is no good and the tailgate is no good, the box well, found one bad spot ( bondo again) and the floor I don't know since it still has the plastic box liner.
The only thing that looks good so far is the front clip, hood, and frame.
Should I just get a better truck and keep this one for parts or just get the metal I need, ( was thinking of getting the LWB stepside box from a 2003, I think it would look sweet with the newer style rounded body lines).
And to top it off, since i now know it will take more $$$ to get it going, it has been put on hold indefinetly.
I have to get my 1990 Bonneville SSE on the road so the fiance has a car to get to work ( I am on the road evryday with our 2003 Malibu).
So make a long ( really long) story short, fix what I have or get another truck ( hard to find a good one up here in Salt Land) and use this one for parts, ( once I get more $$$ I can hide).
Sorry for the long post, just a bit down about it and needed to say it.
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline   Reply With Quote
Old 09-21-2003, 03:57 AM   #2
krue
Designated A-hole!
krue's Avatar
Man that really sucks! Sorry to hear it!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 09-21-2003, 10:00 AM   #3
72MARIO
72MARIO's Avatar
I would look for a southern truck buying a new box and cab you may as well just get a southern truck. Money wise you wil be in the same place.
Trust me I have been thru it.
Chances are that the rad cradel is shot too.
Sorry.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-21-2003, 10:11 AM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
You can piece together a body pretty easy....and if your frame and drivetrain is in OK shape it wouldn't be a bad idea. Unless you want to keep the truck original......
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-21-2003, 10:28 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I would replace the cab unless you are a competnet welder and throw on the newer bed I think the look good just look at all the truck's on this board with the newer bed's.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-21-2003, 10:31 AM   #6
SLS
Finish the'71..or bust!
SLS's Avatar
Has anyone come up with a way (or panel) to match up the wheel openings when using a later bed. Tha is the main thing I don't like about the upgrade....mis-matched wheel openings.
SLS is offline   Reply With Quote
Old 09-23-2003, 02:53 PM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
Well it sound like you have a great oportunity for a frame off resto. If you take the sheet metal off; front clip, box and cab. Redo frame and suspension. Clean and /or rebuild engine, trans and rear. Get it reay for a new cab and box while looking for a southern truck with a good body. my 2cents ...
Rich
1972 K5 Blazer CST Click HERE
Old 09-23-2003, 03:42 PM   #8
oldsub86
Depends what you expect and want etc. If you can do the work yourself, fix what you have and replace later if you can find better. Most of these trucks are a long term work in process and will never be worth what we spend on them anyway so don't get too hung up on now or then - just enjoy.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 09-23-2003, 04:29 PM   #9
busterwivell
If your frame and front end is good, and you are going to put a new box on anyway, I'd find a good cab and swap it out. Then your sheetmetal problems are over, right? If you can't find a good cab up there, I know of lots of them down here (but shipping would be TOUGH)
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 09-23-2003, 04:55 PM   #10
palallin
The title to this thread gives me the willies. . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-23-2003, 11:56 PM   #11
GMC69
GMC69's Avatar
Well that is how I felt knowing that once again I have to put my project on hold.
I think I will still be able to sand it down and get a really good look at it and re-evaluate my situation.
Mike
2019 Silvedrado 4x4
