Old 09-21-2003, 03:20 AM   #1
bad 71 chevy
bad 71 chevy's Avatar
Which is better
A muncie m-21 or an m-20 and what is the big differance with them thanks
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 09-21-2003, 06:59 AM   #2
JimKshortstep4x4
Smile
I am not sure if one is "better" than the other. I guess it would depend on the application. The M-20 is a wide ratio transmission
which means it has a lower ratio first gear, (I believe that it is 2:52 to 1) which will give you greater starting torque. The M-21
is a close ratio transmission and has a higher ratio first gear, 2:20 to 1. Outside of the different first gear ratios the two transmissions are very similiar.
Here is a link that has more information on the Muncies.
Jim
http://www.gearzone.net/kit.htm
