Old 01-24-2016, 06:20 PM   #1
akaupp
700r4 Shift Linkage
Anyone had luck with any aftermarket shift linkages for a 700r4 in a 1970 K10? Dad wants to keep the column shifter in his Suburban.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline   Reply With Quote
Old 01-24-2016, 07:07 PM   #2
hugger6933
Re: 700r4 Shift Linkage
Tons of guys use the column shifter with the 700R4
hugger6933 is offline   Reply With Quote
Old 01-24-2016, 07:13 PM   #3
akaupp
With the stock linkage? It looks like the shackle hanger is going to be in the way to move the pin on the frame forward. I guess I should have mentioned that we opted to move the motor forward 2 inches instead of moving the t-case back and modifying the driveshafts.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
Old 01-24-2016, 09:04 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
I used a car style shift lever hooked directly to the shifter rod coming from the column for my 4l60e.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-24-2016, 09:10 PM   #5
akaupp
Excellent, thank you. I'll look for a car lever and hope it works. I want this thing out of my garage.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
Old 01-25-2016, 01:01 AM   #6
jeh
jeh's Avatar
I used one from Lokar on a BB with a 700r4 and it is in the forward mounting holes. (Hopefully it will work with a Th400)
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 01-25-2016, 01:06 AM   #7
akaupp
We ordered one from Summit, should be here in a few days. Thank you all for the recommendations.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
