Old 01-24-2016, 06:26 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Question for Folks Running Full LED's
I want to put LED's in my 1972 C10 truck for all the outside bulbs, except headlights which we be upgraded but not LED. In the original fuse panel it shows 1 flasher for signal lights and one for the hazard lights. Do I have to replace both flashers with LED flashers so the hazards will work as they should, if I need them, or will just replacing the signal light flasher be sufficient.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 01-24-2016, 07:09 PM   #2
flashed
Re: Question for Folks Running Full LED's
I just had to replace one with a No Load flasher on my 72 . I got it from NAPA .
flashed is offline   Reply With Quote
Old 01-24-2016, 07:19 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Question for Folks Running Full LED's
I replaced both of mine to make them blink right and not be slow are fast depending on what manufacture bulb you use.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-24-2016, 07:37 PM   #4
davepl
davepl's Avatar
Some LED lamps have a shunt load built in so that it's enough draw to run the blinkers; the safer bet is to get one that works with zero load.
Read the package to see what kind of sound it makes though - maybe a full digital one beeps instead of clicks, I'm not sure what happens if there's no physical relay.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-24-2016, 07:43 PM   #5
Already Gone
I am thinking of running pair of these.
http://www.summitracing.com/int/parts/upd-90651
Old 01-24-2016, 08:23 PM   #6
9teen69
9teen69's Avatar
That is the one I replaced both mine with. Works great with all LED.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 01-24-2016, 09:11 PM   #7
flashed
That looks like the same one I used .
Old 01-24-2016, 09:47 PM   #8
Already Gone
Thanks for the replys
Old 01-24-2016, 11:16 PM   #9
Ol red 71
I just finished this same endeavor and it was a pain due to my lack of knowledge with electrical work. If I were you I would do both electronic flashers and make sure you have the reverse polarity adapters in case you have to use them (I did). The biggest thing is making sure you ground your front parking lamps well! Ground your flashers well too. Make sure you grind down to clean metal when grounding all your wires.
1971 c20 LWB Fleet 2wd
'working' Add-on AC & Working heat/defrost
manual transmission w/ Power steering & power brakes
Family owned since 1971
____________________________________
“Life is rough so you gotta be tough” - Johnny Cash
Ol red 71 is offline   Reply With Quote
