Old 01-24-2016, 08:16 PM   #1
John H.
John H.'s Avatar
2 Evap Canisters, brackets, new filters and 1 set of hoses
Package deal: Brackets have been professionally re black phosphated. Two new filters. Both canisters have all three nipples and contents can be heard when shook.
$75 and $18 shipping conus
These will go out FedEx ground. I will need a cell number and email with your payment so shipments can be tracked.
John H. is offline   Reply With Quote
Old 01-24-2016, 08:26 PM   #2
72 Super
72 Super's Avatar
Re: 2 Evap Canisters, brackets, new filters and 1 set of hoses
Do they come with hose and the original 3 way tee? Is so I will take these.
Thanks,
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 01-24-2016, 08:39 PM   #3
John H.
John H.'s Avatar
Ray,
Is the three way T from PCV that T's to carb base and then to the canister? If so, yes but only have one of those. Cant see it in the hoses.
Old 01-24-2016, 08:50 PM   #4
72 Super
72 Super's Avatar
Hi John, Yes that was the one I was referring to. I will take these and the fender seal brackets/seals. Will send pm.
Thank you,
Ray
Old 01-25-2016, 09:33 PM   #5
John H.
John H.'s Avatar
Sold to 72 Super pending payment. Working out combined shipping cost.
Old 01-26-2016, 01:11 AM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Just an observation and apologize in advance if I've hijacked this thread. "loose" charcoal is NOT the indicator the charcoal is good. I know this because I've bought two of them and have the original from my truck. The charcoal didn't budge in the original, I opened it up to find the charcoal was like new, and that was with 100K on it. Climate/exposure may be a factor, but it wasn't on this (Nevada). No loss, the canister finish was poor due to battery acid.
I do not recommend shaking these. Other than the valves, which I can't comment on, what fails is the inner bottom element, which is like foam rubber. It's very thin and when it breaks you lose charcoal, which in turn is reason the charcoal can be shaken. In other words, by shaking it you're contributing to shredding the element. Note, the same element is at the inner top.
That's not to say Rochester packed these tight all the time. I can only account for what I've seen, and my original was packed nicely and go figure still had a good inner bottom element. The two others I bought are beautiful and they both shake. Go figure both inner bottom elements have holes.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-26-2016, 04:24 PM   #7
John H.
John H.'s Avatar
Payment received.
Shipping today, thanks!
