![]() Join Date: May 2014
Do you think CPP shipped me the wrong spindles..??
Do you guys think CPP might have shipped me the wrong spindles.?
My truck is a 1967 C-10 (6-lug) You can see in this picture the outside measurements where the ball joints and A-arms would attach is roughly 8 and 1/2 inches (it is actually more like 8 inches because the ball joint surface is recessed). The CPP spindles I ordered are their "Modular Drop Spindles" part# CP30106-2 for a 1963-70 although there is no part number on the casting. You can see in the photo of the new spindle that the outside measurement is more like 9 inches. And one more picture so you guys can see them both side to side. Does anybody have any ideas.? Is this normal for the new spindle to be 1/2" taller.? I'm pretty sure my truck is original (but you never know).
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
Re: Do you think CPP shipped me the wrong spindles..??
I would put them on and see if they work, but make sure the ball joints are correct for your year. If not, it may be for the 73-87 ball joints. Sorry, my stuff in the newer stuff so I'm of no help
'68 C10 SWB '85 K30 Blazer |
#3 | |
My ball joints are part number2 #101-10037 and #101-10036 which are listed as correct for 1963-1970. So it looks to me that the spindles are machined right for 1967 ball joints but they measure different than my factory ones.? Should I proceed.? I guess the A-arms would be an extra 1/2 apart, does that mean anything or change any alignment measurements.?
I just googled "tall spindles" and it seems like a taller spindle is a good idea for handling and tire wear, so maybe CPP adds a little bit on purpose.?
![]() Join Date: Jan 2007
i'm no expert, but this would leave your upper a-arm sitting higher by 1/2", but the lower a-arm and spring wouldn't change. the spindle angle may change very slightly, but i assume an alignment would fix that. i would not sweat it if the ball joints all fit right. i would not think there would be any conflict with the front rim/tire and the upper a-arm, but that might be something to check.
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Run 'em and get us an after pic!
![]() Join Date: Apr 2008
Most likely it was done on purpose to help camber.
Thanks guys for the responses. I think I will try to phone CPP and see what they say.
There are quite a few stories of faulty machining, although these look machined close to the casting. It may be that post-1967 castings were a bit taller and they use the same castings for all years (and just machine for the different ball joints). I'll post up what I find and, yes, will post pictures.
Here's a shot with just the rear lowered…
Can't wait to get rid of those old 6-lug front wheels and see my steelies all around.
CPP never makes mistakes, just ask them
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#13 |
Lolol
http://i1103.photobucket.com/albums/...e1993/nn-2.jpg |
#14 |
![]() Join Date: Apr 2013
are they drop spindles?
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
#15 |
Yes they are 2" modular drop spindles from CPP.
#16 |
56 - autocross
#17 | |
Maybe they changed over the years and CPP sells one universal size for 67-72..?? Anyway I will find out once I get the alignment done but for now do not know.
#18 |
#19 |
Just was reading an article in Car Craft magazine about installing drop spindles onto a Camaro and they said the spindle manufacturer purposely made teh spindles taller to help with castor or camber (I can't remember which).
