Old 01-25-2016, 04:39 AM   #1
Nev68
Nev68's Avatar
1956 side view mirror mod
Has anyone ever tried to modify or reshape a side view mirror arm on their Taskforce pick up?
Since I have changed my 1956 pickup to Rh drive now the LH side view mirror is totally wrong.
I though it would be easier (and maybe cheaper) to modify the mirror arm than move the entire mirror (i.e drill new holes and then have to repair and repaint)
Not sure if the arm is solid or hollow (like tubing)
It might reshape with some heat but just thought I would ask if anyone has tried.
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 01-25-2016, 08:30 PM   #2
_Ogre
_Ogre's Avatar
Re: 1956 side view mirror mod
ogre tried it and he liked it
with the side mounted spare and a wide spare tire, all i saw in my drivers side mirror was tire
i cut a base out of 3/8'' stainless and used 3/8'' stainless rod to move the mirror out 2''
it works great, i can see behind me now
shop air compressor timer
Old 01-26-2016, 01:03 AM   #3
Nev68
Nev68's Avatar
Nice job.
Did you drill a hole in the plate and weld the rod in or just weld the rod the the face of the plate?
Nev
Old 01-26-2016, 06:50 PM   #4
_Ogre
_Ogre's Avatar
the rod is welded to the plate
i like it so much i'm thinking about doing the pass side too
the old mirror mount in the pic is a repop, installed 22 yrs ago
it came rough and pitted, would like to find ss mirror bolts too
Old 01-27-2016, 01:04 AM   #5
Bangkok Dean
Bangkok Dean's Avatar
I did this also see my 56 truck build thread, the photos were before the chrome plating and before I installed round mirrors.
I did not have to change the passengers side (now drivers side) as it is fine as is.
Bangkok Dean is offline   Reply With Quote
Old 01-27-2016, 02:04 AM   #6
dsraven
Check out some motorcycle sites for mirrors, vibration dampened to top it off.
Old 01-27-2016, 03:45 AM   #7
Nev68
Nev68's Avatar
Thanks Dean.
This might be outside of my skill set and to pay someone in Australia to make that would not be cheap.
Nev
