Old 01-25-2016, 03:38 PM   #1
JMitchell15530
Seat Foam
I am fixing to replace the seat foam for my bench seat in my 70 c10. The seat that is in it is a "spring core" seat, thin layer of foam on springs. I'm having trouble finding replacement foam for this style of seat. Most replacement foam I've found says "full foam". Also I read that the "full foam" and the "spring core" cushions will not interchange on the seat frame. Could ya'll please give me some info? Thanks in advance.
JMitchell15530 is offline   Reply With Quote
Old 01-25-2016, 04:03 PM   #2
Jonlopes
Re: Seat Foam
I am interested as well. Can you tell the difference between the 2 different seats with the seatcover still on?
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 01-25-2016, 04:47 PM   #3
Grumpy old man
Grumpy old man's Avatar
Re: Seat Foam
Go to your local auto upholstery shop and have it replaced or a local foam and fabric store were you can buy a medium density sheet of foam and replace it your self for less than $20.00 . These aftermarket foams sold for replacement are extremely over priced In my opinion .
Grumpy old man is offline   Reply With Quote
Old 01-25-2016, 11:05 PM   #4
Gromit
Re: Seat Foam
Do you have a way to post a photo of your springs/seat frame?
This was a post I did way back when - maybe it will help..
http://67-72chevytrucks.com/vboard/s...d.php?t=677940
Props again to Jeff Lilley Customs in Texas for the original idea... it wasn't my idea I just followed his advice - though he doesn't give detailed steps just the general idea that foam can be shaped...
Gromit is offline   Reply With Quote
Old 01-26-2016, 04:33 AM   #5
swamp rat
swamp rat's Avatar
Re: Seat Foam
Gromit's seat is the full foam seat.
The spring seat has probably no more than a 2" thickness of foam, maybe less? so a sheet of foam will work, but what density? Trial and error?
I'm shocked to see the price on the H/D foam tho, i went to a foam store a while back and the prices of foam were outrageous so i need to find better places to buy foam.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-26-2016, 07:00 AM   #6
Grumpy old man
Re: Seat Foam
You can use this type foam to replace the factory foam on spring core seats ,On full foam seats you just repair the worn out/missing section with new foam glued in place and shaped with a scotch pad on an angle grinder .
http://www.yourautotrim.com/1fufosh.html
Old 01-29-2016, 04:06 PM   #7
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Seat Foam
What thickness medium density foam do you use?
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
