Old 01-25-2016, 09:13 PM   #1
sk8er32283
Electrical Assistance Please!
First of all I am posting here because there is more traffic across this board.
I have a 66 suburban
I have two issues I am trying to solve. Well, with the truck anyways
The first may or may not be specific to a suburban. The license plate light is out and I can not find out how to remove the globe so that I can get at the bulb. I remove the mounting screw and looked it all over for sign of how the globe can be removed. I tried to also just twist off the globe but it doesn't want to twist much at all. The is in pretty good condition so I don't want to be to rough with it.
The second is my rear drivers blinker. All the tail light filaments work as they should accept this one. I have verified voltage at harness connection below the back end and at the light bulb housing and at the little spring loaded connection in the bulb mount. I know the ground is good because the running light filament is fine. My initial though was that the wire may have a high resistance connection, so i rigged a wire from the harness connection below the back end up to the taillight housing to rule out that section of wire. I had the same issue, an oscillating voltage from about 4-9(engine off) volts but the light bulb filament would not work. For ****s and giggles I put my wire rig to the other filament(running light) and it did not work either. I did ohm check the bulb filament to make sure they were good too. Right now, I am thinking that there is some sort of high resistance connection upstream of the under bed harness connection somewhere. But I wanted to know if someone with more electrical issues experience could impart some knowledge on me.
Thanks in advance.
1971 Chevrolet C10(78 motor), Longbed, 69 Bed I think
Quadrajet 4 barrel 7043208, Th350 tranny, No A/C
Various components are lightly to highly modified depending on the number of beers consumed prior to modifications performed.
sk8er32283 is offline   Reply With Quote
Old 01-25-2016, 09:53 PM   #2
akaupp
Re: Electrical Assistance Please!
Does the driver's side brake light work?
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline   Reply With Quote
Old 01-25-2016, 10:38 PM   #3
sk8er32283
The passenger side does and the driver side does not.
Old 01-25-2016, 11:32 PM   #4
Tazimafied
Could be a loose or broken wire under the dash. The only thing you can do now is trace the wire under the dash to see if you can find anything.
Tazimafied is offline   Reply With Quote
Old 01-26-2016, 01:10 AM   #5
Captainfab
60-66 Nut
You'll have to start checking for power in that wire, working your way back to the turn signal switch. It could also be in the turn signal switch.
Old 01-26-2016, 07:37 PM   #6
VictoriaHardware
VictoriaHardware's Avatar
Is this a clam shell or barn door sub?
VictoriaHardware is offline   Reply With Quote
Old 01-26-2016, 10:41 PM   #7
sk8er32283
Clam shell. I can not get the picture to load from my phone.
Old 01-26-2016, 11:58 PM   #8
Tazimafied
Remove the entire light bucket and it should come apart a bit easier. The sheet metal is helping hold everything together.
Old 01-28-2016, 02:12 AM   #9
60chevyjim
60chevyjim's Avatar
looking at the picture , it looks like the bulb and socket pop out from the back side of it
60chevyjim is offline   Reply With Quote
