Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-25-2016, 09:37 PM   #1
1960chevypanel
Suburban side post clip needed
Anyone have an extra one of these clips? I think they're just 60-63. They hold trim on the middle exterior post between the sliding windows.
1960chevypanel is offline   Reply With Quote
Old 01-26-2016, 12:10 AM   #2
Captainfab
60-66 Nut
Re: Suburban side post clip needed
I have only seen that trim piece on the '60-'63 GMC Suburbans. What year of Suburban are you working on?
Old 01-26-2016, 12:18 AM   #3
1960chevypanel
It's a 62 GMC. Thought the 60 Chevy I owned a few years ago had them too, but not sure now..
Old 01-26-2016, 12:36 AM   #4
perro13
perro13's Avatar
the 61 I parted out had them
perro13 is offline   Reply With Quote
Old 01-27-2016, 12:31 PM   #5
ratskin
I've seen clips like those on an Auveco site.
ratskin is offline   Reply With Quote
Old 01-27-2016, 03:09 PM   #6
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
actually would be fairly easy to make with some threaded rod a couple nuts and washers they are covered up with the inside trim so you cant see them when it is all back together
gostranger is offline   Reply With Quote
Old 01-27-2016, 05:43 PM   #7
GMCNUT
GMCNUT's Avatar
maybe a machine screw with the head ground off flatter if necessary to fit under the moulding and JB Weld, solder etc if needed around the head to secure it to the piece of steel you cut as a replica of the original fastener blade
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 02-01-2016, 12:30 AM   #8
1960chevypanel
Shouldn't be that hard to find, I've had bunches of them in the past. Bump.
