01-25-2016, 11:39 PM | #1 |
LS Alt Charge Wire
I currently have my battery mounted under the bed behind the cab on the driver's side. I ran a 1/0 welding cable to a 300 amp marine grade breaker, 1/0 from breaker to the alternator charge terminal, 1/0 cable from charge terminal to starter solenoid. I see plenty of diagrams showing the alt wired between the battery and starter. Any issues with doing it as stated above? Seems fine and starts /charges perfectly (have started numerous times on the rolling chassis). Just didn't want to fry the alt post or something. Not a DC electric pro!
Voltage at all points reads darn near identical / not much voltage drop to speak of at all if any. I will be running a separate 6AWG welding cable circuit from the battery that will have its own protection to a junction block for powering the ECM, main fuse panel inside, and other accessories. Each circuit off junction block will also be properly protected. |
01-26-2016, 09:22 PM | #2 |
Re: LS Alt Charge Wire
When wiring my LSx swap, I used the factory battery cables and fuse block which came with the LSx engine/transmission. If it's good for the general, then it's good for me. the fuse block is located on the side of the alternator/power steering bracket. This fuse block has (3) leads. (1) lead goes to starter. (1) lead goes to alternator. (1) lead goes to battery. I never had a problem with starting or charging. I'll try to post pics or the fuse block as soon as I get a chance.
01-29-2016, 08:22 AM | #3 |
here are the pics as promised. sorry for the late delay. I have to upload these pics from email. if any more are needed. text me at 305-815-6660. the pics are on my phone.
01-29-2016, 09:35 AM | #4 |
Old member
I like that junction box! I may have to go to the local yard and grab a couple of those.
01-30-2016, 08:54 AM | #5 |
If you need one, I may have one in the garage, somewhere. you will need the junction mounting bracket that attaches to the power steering/alternator bracket also. if you cant find one, hit me up Andy4639.
02-03-2016, 12:08 AM | #6 |
Many thanks for the pics. I'd have to do some rearranging of things to make that work as I have up and forward headers that would run right into that bracket.
Just to confirm you have a line running straight from your battery to that junction, straight from the ALT to that junction, and straight from the starter to that junction correct? No fusing between the alternator and that junction (at least not that I can tell). I'll snap a photo of my setup in case anyone else chimes in. Thanks again. |
02-03-2016, 01:53 AM | #7 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-03-2016, 08:51 PM | #8 |
Sorry to hijack your thread but can I run my charge wire from the alternator straight to the battery or do I need it fused?
02-04-2016, 08:30 AM | #9 |
LS1Nova71, Thanks for chiming in. Yes, 1bad396ss. I try to keep things very simple. if its good for the GM, then its great for me. My battery is mounted in the back, on the frame, behind the cab. Hello aod92, if it were me I would. can you post a pic of your alternator, engine bay set up?
02-06-2016, 11:16 AM | #10 |
I have a similar question/situation and not trying to hijack your thread. My battery is in the rear also. I ran the battery cable to the starter. I then ran a wire from the alternator to the starter with a fusible link. Next I ran then fuse panel hot wire to the alternator. Electrically it works, but does anyone see an issue with how I wired this? Thanks in advance and hopefully I contributed to the discussion.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-06-2016, 12:37 PM | #11 |
Hart_Rod. yes it would & should work. I like my junction box idea. it closely resembles GM's idea and the power devices are getting their power from one place(junction Box). Also, in your case the starter and alternator are feeding other devices. they all are connected but I would change it. Please don't make the electrical guru. I was beaten up on a thread for that. For your set up, if you plan to keep it that way, The items that need power, protect the devices, by adding a fusible link.
03-13-2016, 07:56 PM | #12 | |
06-14-2016, 10:44 AM | #13 | |
06-14-2016, 12:19 PM | #14 |
Post Whore
Im not sure about the fuse link, its whatever came on my 81..but my wire size is 10ga..it was also the same one that came on the truck..
