Old 01-26-2016, 10:14 AM   #1
hdff
hdff's Avatar
Hot water valve location
Can someone post up a pic of the exact location of the hot water valve on one inner fender and the correct hose routing for a 71 BB.
Keith
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 01-26-2016, 11:59 AM   #2
tommys72
tommys72's Avatar
Re: Hot water valve location
Is the setup the same for a BB as is is for a SB? If it is, I just put a new water valve and hoses on mine. I could get you pics
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 01-26-2016, 03:14 PM   #3
hdff
hdff's Avatar
i'm not sure...
I see you are I springfield mo. , I came up and bought my truck just south of there in Ozark/nixa area.
"Wanda"
Old 01-26-2016, 03:18 PM   #4
davepl
davepl's Avatar
Sorry not the best photo but it'll get you close, and there are likely holes there already or at least dimples.
They are NOT reversible and you should NOT assume mine is correct in the picture - there's a diagram in the shop manual shows it correctly.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-26-2016, 03:48 PM   #5
hdff
hdff's Avatar
thanks dave, there are no dimples. the Po had replaced the inner fender wells so they are aftermarket and I am going to have to drill the holes.
your hot water valve look backwards is that why you use the disclaimer?
also do you know the correct sizes of the hoses? I looked thru the service man and can't find it, also looking at the pic in the manual it looks like the hose outta the h2o pump goes to the top of the heater the bottom goes ther the hot water valve to the manifold. does this sound correct?
"Wanda"
Old 01-26-2016, 03:57 PM   #6
snipescastle2
snipescastle2's Avatar
Talking Re: Hot water valve location
hoses should be 5/8" and 3/4"
Ben
snipescastle2 is offline   Reply With Quote
Old 01-26-2016, 04:15 PM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Hot water valve location
From what I see it's showing the bottom heater core hose going to water valve then going to intake.
Top heater core hose going straight to water pump.
These are both for AC trucks, I don't know if a non AC truck heater hose route would be any different are not
If my memory is right the hose going straight to the radiator is for a manual truck and it going back into the intake was for Auto's. Are vise versa.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-27-2016, 12:16 AM   #8
tommys72
tommys72's Avatar
Yea I'm close to Ozark, it's right down the road. I'll get a pic of mine in the morning. I used the factory location for mine. Those factory manuals and Andy helped me a lot
Old 01-27-2016, 12:21 AM   #9
tommys72
tommys72's Avatar
Not mine, but mine looks just like this
Old 01-27-2016, 12:58 AM   #10
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Yep, looks just like that. Only shouldn't the hose retainer be mounted to the inner fender about 1.5" forward from the water valve plate?
This water valve business seems to come up every few weeks. I figure to take some good notes on the subject real soon. Heater and evap. box removal begins this weekend. It's a slow process.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-27-2016, 05:47 PM   #11
tommys72
tommys72's Avatar
That hose retainer is gone from mine. Wasn't even there
Old 01-27-2016, 08:15 PM   #12
davepl
davepl's Avatar
I had it backwards at one point but not sure when the picture was taken so just wanted to call that out in case it was backwards, as you suggest it might be!
