01-26-2016, 01:13 PM | #1 |
Are the frames the same?
I currently have a 68 short/wide. I have a line on a 72 blazer in rough shape. My plan is to buy the blazer, repair the body and swap it onto the 68 frame. My question being "is this a straight swap, or will I have to swap my drive train and suspension over to the blazer frame?"
- Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
01-26-2016, 01:21 PM | #2 |
Re: Are the frames the same?
I think the truck frame is longer .
01-26-2016, 02:32 PM | #3 |
Blazer wheelbase is shorter so you'll have to shorten the frame. There are threads here on how to do it.
01-26-2016, 02:44 PM | #4 |
Awesome, so only minor adjustments, nothing major. Thanks.
-Josh
01-26-2016, 03:19 PM | #5 |
Boosted Member
Is it a 2wd Blazer?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
01-26-2016, 03:25 PM | #6 |
4wd.
- Josh
01-26-2016, 03:32 PM | #7 |
Boosted Member
I am fairly certain the body mounts for the blazer tub are in different spots than the cab/bed mounts for the pickup. You'll probably need to measure where they are and cut them off the blazer frame and weld them to the truck frame...not a big deal if you're already cutting the frame to shorten for the 11" wheelbase difference.
Also, the 2wd truck frame is wider in the rear (coil springs) than the leaf spring 4x4 frame.
01-26-2016, 04:13 PM | #8 |
The core support brackets have a larger hole in them, may have to use later core support bushings or buy the older brackets from LMC or cut some off an older frame.
Ben |
