Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 01-26-2016, 03:31 PM   #1
Pro Performance
Pro Performance's Avatar
New Product: Pro Performance Air Bag Spacers!
NEW PRODUCT!
We have recently added another product to our line up. These air bag spacers for the F9000 Firestone sleeve bag will allow you to run less bag pressure at ride height. This is ideal when you are running a shorter tire than your rear suspension is setup for. Or, if you just want a smoother ride, then you can add these spacers under your sleeve bags as well.
For example:
If your rear kit is designed to lay out on a 30" tall tire, but are running a 28" tall tire, you would have to inflate the bag more to make up for that 1" lower ride height it would create. When doing that, it means more pressure.
With the bag spacer, you can now lift up to the desired ride height, and use less pressure for a smoother ride as it was intended to be like. If you decide to go to a larger tire in the future, just remove the spacer.
I recently put these in my truck for the same reason mentioned above. It really helped with ride, and have been running them since.
We have had request to make them for the larger D2600 bags. If demand is enough, we will do it... so let us know.
Aluminum Air Bag Spacer: $49
Pro Performance is offline
Old 01-27-2016, 10:43 PM   #2
knomadd
knomadd's Avatar
Re: New Product: Pro Performance Air Bag Spacers!
I'd definitely be interested in the 2600 spacers. Feel free to delete this if you aren't looking for requests in this thread.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline
Old 01-29-2016, 08:38 AM   #3
Pro Performance
Requests in this thread are good.... thanks for the feedback.
Closed Thread
