Old 01-26-2016, 05:48 PM   #1
uncle
Motorhome Tilt Column
Nice clean,tight column. I hit shift arm area w/my sawzall, but welded slice up, that's why it's shiny on bottom. Needs paint. Has later style harness so you'll need pig tail to adapt to stock truck harness.Qwik has 1st shot at column. $225 shipped to lower 48. Please respond in post. 1st take it gets it.
uncle is offline   Reply With Quote
Old 01-26-2016, 05:48 PM   #2
uncle
Re: Motorhome Tilt Column
Aaaaa
Old 01-26-2016, 05:49 PM   #3
uncle
Bbbbb
Old 01-26-2016, 05:49 PM   #4
uncle
Ccccc
Old 01-26-2016, 05:50 PM   #5
uncle
Dddddd
Old 01-26-2016, 05:51 PM   #6
uncle
Eeeeee
Old 01-26-2016, 07:27 PM   #7
feller
feller's Avatar
Besides a pigtail what else would be needed to make this work in a truck? Next after qwik
feller is offline   Reply With Quote
Old 01-26-2016, 08:54 PM   #8
DPowers
DPowers's Avatar
I'll take it if gets to me.
DPowers is offline   Reply With Quote
Old 01-27-2016, 09:00 AM   #9
72MARIO
72MARIO's Avatar
I am interested in the cruise lever if whoever buys it is not using it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-27-2016, 03:49 PM   #10
uncle
Qwik passed. Feller Neutral switch location and add metal retainer and rubber seals. Dpowers I'll give feller 24hrs to respond. I've been told column can be pushed closer to dash and neutral switch will clear but have never tried it.
Old 01-27-2016, 04:23 PM   #11
feller
feller's Avatar
I'll pass, more work than I am anticipating
Old 01-27-2016, 05:41 PM   #12
29od1
It won't clear even if you push it all the way to the gauge cluster.
29od1 is offline   Reply With Quote
Old 01-27-2016, 07:04 PM   #13
uncle
I got it from a pretty reputable source but like I said I've never done it. DPowers you up
Old 01-27-2016, 07:11 PM   #14
DPowers
DPowers's Avatar
pm sent
Old 02-08-2016, 09:36 PM   #15
DPowers
DPowers's Avatar
Received today- Thanks
