14ff disc brake conversion?
Thinking in the future of upgrading axles to 1tons, know of a cheap set. What are the pros/cons of converting drum to disc. what kinda cost would i be looking at?
1983 Scottsdale K10 496 /t400 fmvb /208 /D60 and 14ff with Locker /35x12.5x15 mt baja mtz 680hp/720ftlbs of NA fun |
Re: 14ff disc brake conversion?
I got my 14BFF off of a '05 2500HD. Disc to disc with E brake cables attached. 300 bones. Guys parents wanted the axle out of their planter box.
IIRC, there are 2 different styles. 10.5" has the removable pinion support. 11.5" has non removable support and hard to get aftermarket cool stuff for. If you have a drum axle already, they are pretty reliable and if maintained also work really well. Disc conversions often use Eldo calipers which will arguably give you the bling of rear disc brakes with possibly worse braking than the drums that are already on there. E brake hardware is always a thought as well. Ive seen a couple of people convert using the newer GM truck hardware but then why not get the whole axle? In the end, had I not picked up the axle so cheap, I probably would have stayed with drums. I think it would probably cost more to convert than the axle itself.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
The cheapest option is to use front calipers off a 1/2 or 3/4 4WD, there are lots of kits that do that. Downside is no ebrake.
I'd love to find a modern 14FF for $300. I'd probably try to adapt it to the 1975 14FF sitting in my bed right now, as it has the gearing/locker that I want and the newer ones are wider.
1973 C20, 350/350 |
user # 2756
![]() Join Date: Jun 2001
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Collector of Projects
Right Gear had brackets to mount the newer brakes on the older 14 BFF axle... not listed on the website so you have to call direct and ask...
Copied from pirate4x4 ::: I've got an '04 AAM 10.5 (14-bolt) under my rig now with the stock discs and a TMR shave. I just went out and measured it and the WMS to WMS was right about 68.5" as I measured it with my set of rollers on there, so it's about as accurate as I could get without dismounting the wheels again. and Right gear and axle in Salinas sells the bracket you need. Give Dan or Jose a call at 831-424-3717 http://rightgear.com/welcome.htm http://www.ebay.com/usr/gears-r-us?rt=nc ************ I bought a complete AAM 11.5 rear assembly, rotor to rotor for $400 shipped. There are 2 versions, One with a counter weight and without. both have the same twin piston rear calipers with drum in hat e-brake. www.car-parts.com /\ || This is a list of dealers and you can sort by distance. Mine was shipped from Arizona to Vegas strapped to a pallet. I picked it up at the depot to save a few bucks. If you do go this route, make sure they include all the brake parts including calipers and rotors. Also, stay in the dry climate area so rust isn't a problem... The picture is of the Right Gear adapter bracket... |
if you want ebrake, the factory setup is the way to go, and its cheaper to get an axle with it already.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
The problem is that the newer axles with factory discs are wider.
1973 C20, 350/350 |
#8 | |
Chris
Here is my 72 with an 05 14BFF AAM rear on H2 wheels and 315/75/17 BFG tires. Looks perfect to me.
And yes, GM designed the front to be wider than the rear. I think it looks better with the rear not to tucked under the truck. Also, wider is better... |
On the other hand, for a tow rig with stock fenders (or in my case a utility bed), wider might not work.
1973 C20, 350/350 |
After its all said and done, swapping in a newer rear assembly is the way to go I'd have to agree. Ebrake cables are easy-just measure overall length, take closeup pics of both attachment ends you need for reference and call or email controlcables.com and they can build any cable you need. Figure roughly $125-150 for a set of custom cables to work with your truck.
#13 | |
How about a picture of your truck? |
#14 |
Nothing special. I found a 1975 14ff with the 3.73s I want and a G80 locker (very streetable I hear) to replace the 4.10 open I have now. Planning an LS and 4L80E when I find the right deal. Maybe turbo when I get bored. Tires are in great shape so I doubt I'll replace them any time soon unless a turbo LS makes them wear out too quickly ![]()
1973 C20, 350/350 |
#15 |
Well it looks like you could cut a larger square out of the bedside to match the factory opening. Maybe add some fender flares... Custom but functional that would match the front fender openings and allow bigger tires if needed....
#16 |
I could, I'd rather not.
I think I've decided I should just buy a no-ebrake setup for the 3.73 G80 axle I have sitting in the back. The axle will bolt right in, which is convenient, and since my ebrake isn't working anyway (hasn't since I bought the truck) I'm not losing much. I can chock it if I need to (obviously I will for replacing the axle). Thoughts on which kit is best? Any options I should go with? Also, I probably ought to replace the front brake hoses. As with many components on it I suspect they're original. I'm talking about the soft part, since there's no real rust on the truck the hardlines seem fine.
1973 C20, 350/350 |
