Old 01-27-2016, 12:29 AM   #1
Brad54
Brad54's Avatar
Short-arm rear view mirrors: application?
What did the short-arm outside rear view arms come on?
And, did they have the round rear view mirrors, or the square ones?
If round, were they the center-mount style, or the ones with the offset mount?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 01-27-2016, 08:58 AM   #2
jbgroby
jbgroby's Avatar
Re: Short-arm rear view mirrors: application?
Didn't know there was a difference in the arm length, but the trucks originally came with round mirrors on the drivers side. The passenger side mirror (as many parts) were an option. I have both the round and the rectangular. But as I have been told the rectangular style shake badly when driving at highway speeds.
jbgroby is offline   Reply With Quote
Old 01-27-2016, 09:29 AM   #3
ol_skool_chevy
ol_skool_chevy's Avatar
I have never seen a short mirror. But I cut a set down and welded them . And I have seen the polished aftermarket once cut down they are stainless steel so its pretty easy to cut and re polish them if they look too long
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 01-27-2016, 10:50 AM   #4
60-66
60-66's Avatar
The G series Vans used the short arm mirrors . Heres an NOS one for 1963-1966. The Suburban term here on the box also relates to the G series again not our C series. Same offset mirror as our trucks and same bolt pattern on the bracket. 60-62 was a Cast arm shorter length for Vans. The square or rectangular mirrors were available as an accessory.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-27-2016, 11:58 AM   #5
Brad54
Brad54's Avatar
I've got on of those van mirrors... I'd love to get one for the opposite side for a match.
I'm talking about the short cast-iron mirrors, like these in the For Sale section:
http://67-72chevytrucks.com/vboard/s...d.php?t=694125
I've got one of them, too, but wanted to know it's application.
-Brad
Old 01-27-2016, 12:29 PM   #6
60-66
60-66's Avatar
Yes , I knew which ones you meant. The short cast mirror arms were used 1960-1962 . Maybe I used the wrong terminology I guess in saying Van , its Corvair and FC models that used that arm you are referring to.
Old 01-27-2016, 05:38 PM   #7
Brad54
Brad54's Avatar
Okay... still confused.
There's the long arm that we're all familiar with, and they go on the pick-up trucks.
There's a version of the long arm that is cast, and those go on the early trucks.
There's a short curved arm that apparently goes on Corvans. (the NOS one you have)
There's also a short straight cast arm. Wondering what THAT one goes on.
-Brad
Old 01-27-2016, 07:24 PM   #8
60-66
60-66's Avatar
Okay , show us this arm your talking about ? If its the one from the thread you posted above then that's the one in the last picture I posted in post 6
Old 01-27-2016, 08:31 PM   #9
Brad54
Brad54's Avatar
The one in the last pic is the short, straight cast arm, and it's on a Corvain (FC).
The curved-arm NOS one you posted you identified as being from a van.
So the short ones, then, curved and straight, are FC?
In the mirrors for sale post, someone identifies the short ones as being '60 pick-up truck (or '61... I forget now).
-Brad
Old 01-27-2016, 09:21 PM   #10
jtrichard
This is from the for sale post .. about the cast arms ....
Great question - so the answer is 1960 & 1961, and they came on both Chevy and GMC. The interesting thing is that the longer arms you see on the left are all off 1961 trucks - only 1960 came with the short version you see on the right. Most people do not know this odd fact, so you will see them at shows with the wrong mirror arms on either year because they bought them off Ebay or wherever without knowing.
jtrichard is offline   Reply With Quote
Old 01-27-2016, 09:53 PM   #11
60-66
60-66's Avatar
Okay , I see Brad. Digging a little deeper here I found two perfect examples of a 1962 14,000 mile original paint Chevy with the cast mirror arm with matching paint. Then a 1962 GMC with the stamped steel mirror bracket , truck has 1700 original miles. I cant find anything to support the short mirror bracket for 1960 however looking through a 1959 dated parts book for 1960 model trucks they DO list a short AND a long arm mirror bracket .
I have an NOS RH cast short arm part number 3773368 http://gmpartswiki.com/getpage?pageid=26914
This one is 6 inches in length.
Then go to 1960, 1961, and 1962 Chevrolet Data books and a 1960 GMC data book and each book confirms an 8 inch fixed length mirror arm as standard equipment for our trucks which is the length of the long arm mirror bracket.
It would seem to me ( I have learned a lot looking this up today ) that the short arm might be a problem viewing ? the mirror with the vent window is so close ? I dont know , never had a short arm on one of my trucks.
Interesting , now I have something else to investigate. I will ask GMCnut more about what he said.
Old 01-27-2016, 11:33 PM   #12
60-66
60-66's Avatar
This is the new 1960 with 3 miles from the Lambrect auction showing the long arm.
Old 01-27-2016, 11:53 PM   #13
60-66
60-66's Avatar
Then heres another 60 with the short arm. This was in the most original thread. Supposed to be an original paint truck also. Im noticing a pattern on the 60 trucks that the mirror arms are black.
Old 01-28-2016, 12:00 AM   #14
'63GENIII
'63GENIII's Avatar
Do all of the round mirrors have the offset mounting stud? I think I have only seen the mirrors with the mounting stud in the center of the back of the mirror.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-28-2016, 12:17 AM   #15
Brad54
Brad54's Avatar
Glad you were able to dig stuff up!
I've got one of the short arms for the driver's side--and you're right, it was impossible to see out of it, because it's right in line with the vent window frame.
I'd also be interested to know why some of the round mirrors have the off-set mounting stud, while others are center-stud.
-Brad
Old 01-28-2016, 10:28 AM   #16
60-66
60-66's Avatar
-Brad
That I can say , for 1960-1966 there were two very similar round mirrors. Both have offset mounting studs. The 1960-1963 style was a little thicker and the 64-66 was thinner. The center stud style was used in the 59 and older trucks and then again in the 67-69 maybe 70 vintage trucks. Also remember these mirrors were replaced in their 50 plus years with different aftermarket styles. Heres a comparison picture of the original GM 60-66 offset mirrors. The thinner 64-66 is on the left.
Old 01-28-2016, 12:03 PM   #17
oem4me
I thought it was reversed. Thinner being earlier. This is based upon my two untouched survivors (1965 Sub and 1966 C-10) both having thick mirrors with three adjusting screws.
Old 01-28-2016, 12:41 PM   #18
60-66
60-66's Avatar
All I can say Bruce is that all the new Lambrecht trucks 64-66 had the thin mirrors and the 63 down had the wide mirrors. I took lots of pictures of these trucks. There was a little overlap I noticed from 63-64 . I personally have never seen an original 65 66 with the wide mirrors.
The thicker mirror is part number 3765480 . Heres one on Ebay for reference http://www.ebay.com/itm/NOS-GM-Mirro...p2047675.l2557
Heres the wide mirror 3765480 in the parts book. http://gmpartswiki.com/getpage?pageid=66566
States 1960-1963
3838535 mirror in the parts book started in 1964 and is the thinner mirror. This is defined in a 1964 Chevrolet parts book.
Hope this helps.
Old 01-28-2016, 12:49 PM   #19
60-66
60-66's Avatar
For mirror arms , heres the later 63-66 arm part number 3816677 .http://www.ebay.com/itm/60-1961-1962...p2047675.l2557 Seller has it labled by mistake (common) as fitting 60-66 .
Here is this arm 3816677 in the Chevrolet parts book http://gmpartswiki.com/getpage?pageid=66570 . This is an October 1962 parts book , this is early in the 1963 production year showing the beginning of the stamped steel mirror arm. They refer to it as a "short arm" when its the 8 inch arm.
Old 01-28-2016, 02:14 PM   #20
oem4me
Hope this helps.
This does not help. Conversely, it hurts. All this time I've been under the impression my babies were pure, undefiled, virginal survivors. Turns out they are tainted, spoiled, whore trucks. Dang! Lol.
I'm not giving up this yet...
Old 01-28-2016, 02:29 PM   #21
60-66
60-66's Avatar
Old 01-28-2016, 02:49 PM   #22
jbgroby
jbgroby's Avatar
be careful, you will be accused of trafficking in trucks........
