custom inner fenders for slammed trucks?
I know about Slosh tubz, and hills rod and custom makes some that looks like the factory inner fenders. Does anyone know if there're some that will work with factory hood hinges? Thanks in advance
Re: custom inner fenders for slammed trucks?
Anyone got pictures of Slosh tubz or hills rod and custom ones? How hard are they to install? Would they be easy to install on an already painted truck?
#3 | |
![]() Join Date: Apr 2005
http://67-72chevytrucks.com/vboard/s...d.php?t=551258 There are a lot of pictures of the SloshTubz on our board, you will just have to do a search. You can install the either of those tubs on a painted truck, you will just have to be very careful and tape stuff up.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Thank you very much! Your truck looks great!
Thanks. Since your truck is painted, if you go with Porterbuilt hood hinges, you may be interested in these:
http://67-72chevytrucks.com/vboard/s...d.php?t=679945 Let me know.
Thank you! Those brackets are great! Might just have to do that! Do the hills tubs bolt right in, I know you have to cut the inner part of the fender. Can you still run the factory battery tray?
Yes they bolt in once the fender is cut. You can't use the factory battery tray. Let me know about the hood brackets.
#8 | |
I ask, because i noticed how well your wheels/tires tucked on the stepside and wanted to ask the wheel size and back spacing specs. thanks! |
Any chance of doing a run for 66?
Are you talking about the rear tubz?
No 66 fronts
I don't make the fronts, only the rears. You'll need to talk to SloshTubz about the front ones.
#13 |
My wheels just barely tuck the inside lip has been trimmed on my rear fenders. I think the rear end is out of a 70.
#14 |
#15 |
I used a drop down battery box mounted on the passengers side underneath the bed floor.
#16 |
Are the hills inner fenders fiberglass ?
#17 |
67-72 parts collector,…
![]() Join Date: Nov 2002
#18 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-01-2016 at 10:11 AM. |
#19 |
I remember watching gas monkey when they installed slosh's on a square body and Arron made them seem like a pain in the butt to install.
#20 |
the boat guy
Mike losh. Slosh tubs. Boosted bertha. Sema.... they are being made.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#21 |
