Old 01-27-2016, 01:49 PM   #1
Coach529
Coach529's Avatar
Clearance around bags
I am installing some Slam Specialties SS-7 bags in my 1949 Chevy 3600.
Thunderbird IRS in the back, Scott Danforth Cross Member in the front.
I am setting the back up now and I am a little tight on space with the 7" bag. I plan to open up the notch a little since I have room available.
Is there a rule of thumb.....or a guideline on how clearance you should have around the bag to prevent chaffing or a rub?
Thanks in advance?
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-27-2016, 02:23 PM   #2
PGSigns
PGSigns's Avatar
Re: Clearance around bags
I try and make sure I have a 1/2 inch. On you welds, slow down on the travel and maybe turn up the heat. The ones on the sides look like they have little penetration.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-27-2016, 02:42 PM   #3
Coach529
Coach529's Avatar
Jimmy
Thanks for the input.
1949 Chevy 3600
Old 01-28-2016, 03:01 AM   #4
andrewmp6
I was always told a finger gap between the bag and anything it could touch.Anything the bag rubs on could rub a hole in it over time since its rubber.
andrewmp6 is offline   Reply With Quote
Old 01-28-2016, 10:55 AM   #5
Coach529
Coach529's Avatar
That is what I am shooting for.
Thanks!!
1949 Chevy 3600
Old 01-28-2016, 10:57 AM   #6
SCOTI
SCOTI's Avatar
Why not go w/a smaller OD bag? The 7" bag is better suited for the front weight bias on a truck.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-28-2016, 10:59 AM   #7
Coach529
Coach529's Avatar
That was an option that I thought about as well.
I just really did not want to go through the hassle of selling these bags, buying new, etc.
1949 Chevy 3600
Old 01-28-2016, 11:03 AM   #8
SCOTI
SCOTI's Avatar
Seems easier vs the option of cutting & opening up the notch more since it appears a little thin as-is (might just be the angle on the pics).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-28-2016, 11:18 AM   #9
Coach529
Coach529's Avatar
I am not too worried about the integrity of the notch, but you have me thinking.
Is there a ride quality difference between the two bags?
1949 Chevy 3600
Old 01-28-2016, 11:53 AM   #10
SCOTI
SCOTI's Avatar
Yes, there can be a difference but 'how much' is subjective. Some guys run the larger bags in the rear & use less pressure to achieve ride height for a better ride. I tried that on my 68 (7" bag equivalent) on the rear & found I was @ <30psi for my ride height. It basically had no spring rate @ that low of a pressure & the result was a very bouncy ride quality. By swapping to smaller bags I had to increase the inflation pressure to achieve the same ride height. Now I was @ ~40psi & no more bouncy ride (same shocks used for both).
Some guys may not notice. I definitely could.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
