Old 01-27-2016, 08:12 PM   #1
Tod59
'59 Headlight Question
Hey Guys,
I'm restoring my '59 headlight buckets (cleaning, painting and new adjusters).....
Question: Is the 3 prong headlight placed on the "outside" headlight bucket? Is the 3 prong headlight the "regular" light?
Essentially, the 3 prong light is the "regular" headlight and the 2 prong headlight is the inside of the bucket "bright" light (combined with the regular outside headlight)?
Hope this makes sense.
Tod
Tod59 is offline   Reply With Quote
Old 01-27-2016, 08:34 PM   #2
_Ogre
_Ogre's Avatar
Re: '59 Headlight Question
3 prong is hi/low, 2 prong is hi only, 3 prong to the outside
low beam is only one bulb, hi beam is both on hi
new adjusters make all the difference and they're cheap too
shop air compressor timer
Old 01-27-2016, 08:37 PM   #3
Tod59
Thank you.
Old 01-28-2016, 07:15 PM   #4
OrrieG
OrrieG's Avatar
Clean up, paint, new wire and adjusters. I got my adjusters from a place off ebay called Florida Fastners. $9 for 4 (will do both 55-57 or 1 58-59), if you watch they have free shipping now and then. The adjusters are thicker than the original but use the same screw end configuration to fit the stock headlamp. Wire harness came from Classic Parts has all the right grommets, etc. Tan is outside, green inside.
OrrieG is offline   Reply With Quote
Old 01-28-2016, 07:23 PM   #5
Tod59
Thanks! However, I bought some used buckets from a place in Canada and ordered a new set of adjusters at the same time. I found that I had to chase the threads in the plastic adjusters with a 1/4-28 fine thread tap so the adjuster screws would screw in.
Sounds like you got a good deal on the cost. Thanks for your help.
Next year I plan on rewiring the truck with an AAW kit.
