Old 01-27-2016, 10:08 PM   #1
Jraney
64 instrument panel removal
Hey folks how do I go about removing the instrument panel from the dash. I have removed the screws but not the light, wiper, & other knobs. How do I do that. I cannot seem to find a video or anything anywhere. Thanks
Jraney is offline   Reply With Quote
Old 01-27-2016, 10:46 PM   #2
j.kirn
Re: 64 instrument panel removal
The headlight switch has a pin you have to press on the side of it then turn and pull, the choke cable has a nut on back side you have to remove and from carb, the wiper knob has a set screw on the side of it, and you have to unscrew the speedo cable from the back side
j.kirn is offline   Reply With Quote
Old 01-27-2016, 11:02 PM   #3
PGSigns
PGSigns's Avatar
Then un screw the bezel on the ignition switch and it will come out. The wiring is up about the same area as the speedo cable there will be 2 connectors.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-28-2016, 11:32 AM   #4
Jraney
Hey thanks fellas.
