Rear wheel hub bearings to grease or not to grease
So I am changing my rear hub bearings on a Dana 60 rear end. I read that you should not grease the bearings before installing them as they are lubricated by the differential fluid once the wheels get going. Seems like a scary idea to me but what do I know?
Can someone weigh in on this? |
Re: Rear wheel hub bearings to grease or not to grease
Do not grease them you will not get your end play correct as soon as the hot gear oil washed the grease away you will have to much end play and will damage the bearings
Good to know because I was fully prepared to pack them full of grease. Thanks
I always jack up the rear end on the side with the fill plug fill it with a little extra oil then pull it up on dirt bank around the yard on both side and let it set for a little bit then check the level
This is the way I do it I also check it again after a couple of miles just for piece of mind
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
