Old 01-27-2016, 11:13 PM   #1
Isaiah92260
Isaiah92260's Avatar
Help with wiring please!
So I have a brand new 120 volt alternator that works great and charges at 14.7, no problems.... But my question is, why does my instrument lights at night dim when I press on the brakes when I'm driving at night? Is that because I have the original wire harness present and I have weak connections? All my alternator wiring I did replace under the hood, I do also have a some what weak batter that gives me 12.3 when the truck is off. I do plan I on eventually replacing my batter and wiring new, just wondering if there is anything I should worry about?
Isaiah92260 is offline   Reply With Quote
Old 01-27-2016, 11:24 PM   #2
jtrichard
Re: Help with wiring please!
probably bad connection most likely in fuse block
jtrichard is offline   Reply With Quote
Old 01-28-2016, 11:40 AM   #3
PGSigns
PGSigns's Avatar
Also check the wiring you replaced to make sure you have it all where it needs to go. If you show us what you have we may be able to give you more suggestions.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-28-2016, 01:59 PM   #4
gmachinz
GM really didn't allow for much in terms of current capacity with the OEM style bulkhead. What, I believe a single 12ga twin lock terminal all provides all the interior power-only to get rerouted back out for things such as lights....? Yep, not efficient. Have you successfully converted to (I assume here....) an internally regulated alternator? That'd be step 1 in my book.
gmachinz is offline   Reply With Quote
Old 01-28-2016, 02:48 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Clean all connections on all the plugs. Make sure you have good grounds to the body, chassis and engine. These two things solve 95% of most electrical problems in old vehicles.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
