Old 01-27-2016, 11:30 PM   #1
Gillnetter
Gillnetter's Avatar
E Brake cable question?
How do you get the e Brake cable out through the frame?I have disconnected it from the rear cable and wanting to leave it attached to the cab.Is this possible?Any suggestions.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 01-28-2016, 08:38 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: E Brake cable question?
No problem. The cable should have a union along the trailing arms. Loosen the brake cable adjusting nut up under the truck. Drivers side by transmission at the y connection. Then undo the union and c clip for the cables on each side.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-28-2016, 01:19 PM   #3
midniteblues
midniteblues's Avatar
http://67-72chevytrucks.com/vboard/s...489394&page=14
this is a great thread. it needs a ttt.
page 14
post #336
they can be a bugger but this will help. also works on the e brake cables going through the rear backing plates.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-28-2016, 02:09 PM   #4
Gillnetter
Gillnetter's Avatar
Thanks guys. I will try the hose clamp trick.
