Old 01-27-2016, 11:45 PM   #1
Miller197
Right Hand Drive Conversion
Hey
Plans have been made to convert my 55 chev from LHD to RHD (aussie truck)
The brake pedal bracket will need to be flipped and i will need a rhd steering rack and a new hole for the column etc etc etc But the dash is my concern.
I was planning on cutting a LHD dash to bits and changing everything over and then welding it back together.. the difficulties lies in trying to cut out the hump and move it over so that the curves on either end of the dash stay as they are..
Or would it be easiest to get a sedan bel air twin hump dash and use that
and tips or pics would be appreciated
Cheers
Miller
Miller197 is offline   Reply With Quote
Old 01-28-2016, 01:17 AM   #2
mr48chev
mr48chev's Avatar
Re: Right Hand Drive Conversion
If you plan to move the glove box to the other side careful cutting might save a lot of fabricating and welding.
Or is there a great looking dash from a late 50's or 60's Australian rig that might just fit in there with a bit of fitting? Something that will look perfect in the truck and fit without an extreme amount of work?
My ongoing truck projects:
Old 01-28-2016, 02:14 AM   #3
Miller197
The glove box will be shifting over to the left hand side.. I found a couple pics of a RHD conversion that was done with some careful measuring so it went straight over.. but from what I could see there was a lot of fiddling to get right curve at the end which then created a bezel fitment issue
I haven't really thought about retro-fitting a dash out of something else, wouldn't mind keeping it as chevy as possible
Old 01-28-2016, 08:50 AM   #4
1project2many
You might try contacting user Nev68.
http://67-72chevytrucks.com/vboard/s...ighlight=Nev68
1project2many is offline   Reply With Quote
Old 01-28-2016, 11:12 AM   #5
MARTINSR
MARTINSR's Avatar
I love this mod. The US AD trucks had a hump in the firewall on the right side where the column would go for right hand.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 01-28-2016, 12:30 PM   #6
mr48chev
mr48chev's Avatar
Seeing the example I'd say it would be well worth the effort to get it right even though it may take a lot of hours of work and possibly learning some new fabrication skills.
Old 01-28-2016, 06:45 PM   #7
Miller197
Nev's conversion ame out looking really clean, ill have to contact him when i get closer to action.
Would a bel-air dash be useable? or are they narrower then a pickup
Old 01-28-2016, 07:05 PM   #8
OrrieG
OrrieG's Avatar
The factory assembly manual shows all the stuff required for Right Hand Drive, I think in the RPO section at back. Besides the dash, steering, clutch and brake stuff and shift linkage are the biggies.
OrrieG is offline   Reply With Quote
Old 01-29-2016, 12:08 AM   #9
1project2many
The car dash does not fit directly, but here's something else to look at:
http://67-72chevytrucks.com/vboard/s...&postcount=794
Old 01-29-2016, 02:01 AM   #10
Miller197
Cheers OrrieG, I’ll have a look into that manual. The truck came pretty bare..we don’t have a brake pedal, shift assembly etc, etc so we will be starting from scratch on the most part. The truck did come with a brand new LHD steering rack which we won’t be able to use
I don’t mind the twin hump look at all.. I was reading on google the bel air’s are slightly narrower? I guess a bel air dash could be cut in half and then welded back into place in the pickup which would maintain the curves and then cut out a hole for the gauge bezel
Old 01-29-2016, 02:59 AM   #11
Nev68
Nev68's Avatar
I am using a Commodore brake pedal, master cylinder and booster.
Steering column is IDIDIT
IFS is XJ6 Series 2
I thought about keeping the original front end but 1 drive convinced me to go for the IFS and that gave me some nice disc brakes up front as well
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 01-29-2016, 03:01 AM   #12
Nev68
Nev68's Avatar
I really thought about doing a dash like this but ended up keeping the "truck" style dash, which I like as well.
Nev
Old 01-30-2016, 04:31 AM   #13
Miller197
Did you use a jag steering rack with the Xj6 front end?
Pulled out the LHD ford power rack that was in it today. Tossing up weather to put another power rack back in or just for a manual rack and keep it simple.
Old 01-30-2016, 10:40 PM   #14
Nev68
Nev68's Avatar
Yes, I kept the jag rack
Nev
Old 01-31-2016, 11:37 PM   #15
steampunk c1
Hi im also downunder in new zealand and currantly fitting jag xj infront and rear and looking for lh jag rack to keep lhd drive. If you dont use your rack I would love a chance to buy as they a thin on the ground down heare.
steampunk c1 is offline   Reply With Quote
Old 02-01-2016, 09:23 PM   #16
Miller197
steampunk if your referring to the steering rack that I posted a photo of that was a power rack off a ford mustang front end
Old 02-02-2016, 03:04 PM   #17
steampunk c1
Thanks for that it is hard to find a lhd jag rack so I had to ask.I am on the lookout for a power steer rack the right size to prevent bump steer. I may buy a jag rack on ebay.
Old 02-02-2016, 10:19 PM   #18
Nev68
Nev68's Avatar
The jag racks don't come up on Aus ebay that often but i know a jag wrecker in Melbourne that i get parts from.
Nev
Old 02-07-2016, 02:38 AM   #19
Bangkok Dean
Bangkok Dean's Avatar
I did the change over a couple of years ago and used a jeep power steering box.
See my build thread..
Bangkok Dean is offline   Reply With Quote
Old 02-07-2016, 08:53 AM   #20
1project2many
That's a good idea. In the US RH drive Jeeps were used to deliver mail in rural areas. I know some parts for RH drive Jeeps are still available here.
Old 02-21-2017, 11:13 PM   #21
Miller197
Hey,
We completed the conversion a couple weeks back so i thought i would check back in and show you guys how it went... And just in case someone in the future is going down the same road
Its not 100% finished. Just needs some high build primer and a final sand
Old 02-21-2017, 11:33 PM   #22
mr48chev
mr48chev's Avatar
Looks good, and it should look great when finished.
Old 02-22-2017, 03:39 AM   #23
Bangkok Dean
Nice work you are getting close.
Old 02-22-2017, 04:24 PM   #24
_Ogre
_Ogre's Avatar
i have to admire the work you guys in rhd countries do to keep old trucks alive
shop air compressor timer
Old 02-22-2017, 04:41 PM   #25
58CameoAZ
Always wondered about driving from the right seat and in the Left lane?
Think it would be crazy for me as if i were in the situation i would have a panic attack
if i was say driving for awhile and forgot were i was at, Lol...
I guess what i am really saying is if i was ever to be able to be in your beautiful part of the world, i would have to leave the driving to a Local,Lol
Great work on converting your truck!
Allen
58CameoAZ is offline   Reply With Quote
