Robert Olson Transport
![]() Join Date: Oct 2002
another transfer case question
truck is a 79. I believe I have the NP203 transfer case
truck is not going tonto any drive gear It will not shift into reverse or forward gears. At one point it was making a grinding gear noise now its not with the rears in the air the driveshafts will move when you spin the tires both front and rear When you look under the truck it looks like the trans is going into gear when you pop it into reverse or drive yet there is no transfer or power from trans to wheels.... Am I correct in thinking that the chain between the sections int he transfer case has popped? Also just for my own information, I am told there are different size output shafts that are between the trans and transfer case... if you have a mistmatched shaft/case , will they physically bolt up and allow the truck to move at all? I was driving this truck somewhat locally for a few days not in 4wd. We were getting snow so I put the plow on and parked it started it up after snowing went to put in 4wd and plow truck wouldn't move.. this truck sits a lot and hasn't really moved far in several years,,, any ideas?
Re: another transfer case question
It sounds like the transfer is in neutral unless the trans is out of fluid.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
yeah it sounds like something with the transfer case.
when you say you were driving around not it 4wd do you mean not in 4LOC? or you have a part time kit installed? |
the truck was driving the 4wd light on the dash was not lit so I have to believe it was not in lock... you can shift all the way up or all the way back and it lights up its in 4wd
