01-28-2016, 08:31 PM | #1 |
Help finding stock fuel tank sending unit for -10an fitting
Need more fuel for new build...dont want to put in fuel cell. Can anyone lead me to anyone who sales or can make me a sending fuel sending unit to fit my stock behind the seat tank. I need it to fit 5/8 line. thx..
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike Last edited by hardwaycooke; 01-28-2016 at 09:00 PM. |
01-28-2016, 08:48 PM | #2 |
Re: Help finding stock fuel tank sending unit for -10an fitting
http://tristarrradiator.com
Had them build me a new sending unit for the 45+gallon suburban tank. They did good work. |
01-28-2016, 09:00 PM | #3 | |
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
01-28-2016, 09:24 PM | #4 |
Are you using a stock c10 tank?
01-28-2016, 09:31 PM | #5 |
01-28-2016, 09:34 PM | #6 |
Take and cut up a stock one add bigger tubing weld on the -10
01-28-2016, 09:36 PM | #7 |
buying one now to do that...thx!!
01-28-2016, 09:40 PM | #8 |
01-28-2016, 09:41 PM | #9 |
restriction...explain please
01-28-2016, 09:42 PM | #10 |
01-28-2016, 09:45 PM | #11 |
5/8 to pump..no restrictions
01-28-2016, 09:49 PM | #12 |
You don't need to weld a -10 fitting on the tube end, just use one of these;
http://www.summitracing.com/parts/su...080b/overview/ I recently finished a fuel injection install and these are way easy to assemble, I even bent up my own lines. Easy button.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
01-28-2016, 09:55 PM | #13 | |
