Old 01-28-2016, 10:02 PM   #1
68c10owner
68c10owner's Avatar
weighed my truck today
I am a truck driver and started a new job this week. Finally had a chance to pull up on the scale to see what my 85 swb weighed. With me in it the scale said 3960lbs. Im not sure how accurate it is but its gotta be close so we dont over load the trucks. I was expecting it to weigh more.
Anthony
68c10owner is offline   Reply With Quote
Old 01-28-2016, 10:37 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: weighed my truck today
Thank you for posting.
What engine and trans? What do you weigh, if you don't mind saying, so we can subtract that out?
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-28-2016, 10:39 PM   #3
slotard
I think mine's around 5200 + me, but that's with a utility bed and some tools. C20, 350/350.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-28-2016, 10:46 PM   #4
68c10owner
68c10owner's Avatar
What engine and trans? What do you weigh, if you don't mind saying, so we can Subtract that out?
305/700R4, GMC Sierra Classic so power windows, locks, A/C Cruise, tilt, dual tanks. Does have aluminum wheels. and only using one tank which should be about 3/4 full, fuel gauge inop at the moment. Im about 280lbs. The scale isnt CAT certified but its got to be close so our trucks arent over weight.
Anthony
Old 01-29-2016, 12:33 AM   #5
Mtrhd329
4185 with my 260 pounds ass in it. 5.3l 4l80e caprice 10 bolt. 1/2 ton with fleetside bed floor welded into stepside bed.
Mtrhd329 is offline   Reply With Quote
Old 01-29-2016, 12:49 AM   #6
SkinnyG
SkinnyG's Avatar
Both my local landfill scale and metal recyclers scale all say my '77 Silverado SB is 4400lbs with me in it (165lbs). Mind you, one of the two fuel tanks is always full....
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-29-2016, 01:10 AM   #7
68c10owner
68c10owner's Avatar
I know it will depend on options but are some years heavier or lighter than others? Seems a couple members are getting much heavier weights than I did. Not really a big deal to me, I did it out of curiousity more than anything because it was right there.
Anthony
Old 01-29-2016, 03:56 AM   #8
wilkin250r
wilkin250r's Avatar
For those curious, a gallon of gasoline is 6.3lbs, so a full 20 gallon tank is 126lbs.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-29-2016, 07:44 AM   #9
Keith Seymore
Model - to - model should be pretty steady for a base weight, and then variation added based on option content.
There's going to be a significant spread as you start talking about different models (a C20 or K30 is going to be way heavier than a SWB C10).
K
1979-1986
1986 - 2019
Old 01-29-2016, 07:47 AM   #10
Keith Seymore
So: 4400 - 165 - (6.3x32) = 4034 lbs
3960 - 280 - (6.3x12) = 3604 lbs.
Could there be a 400 lbs swing in the front end sheet metal? ('73-'80 vs '81-'87)?
K
1979-1986
1986 - 2019
Old 01-29-2016, 07:55 AM   #11
Keith Seymore
GM Heritage Center archive info:
'77 curb weight (with a 6 cyl) is 3620 lbs; "model weight" (with passengers) is 4070 lbs.
'85 shows as 3486 curb; 3936 model weight.
K
1979-1986
1986 - 2019
Old 01-29-2016, 09:35 PM   #12
Cthibo500
Cthibo500's Avatar
Weighed my 81 reg cab 2wd stepside. At the time had a 350 sbc. Aluminum intake 4 speed Muncie 10 bolt rear 28 inch MT indy profiles, full interior, bucket seats, custom center console with full stereo. 1/2 tank of fuel 8 gallons. Weight 3860 without me in it. So you're about right.
-Real Men Use THREE Pedals-
-Built not bought-
-I'd rather do my own work wrong than pay someone to do it right-
Cthibo500 is offline   Reply With Quote
Old 01-30-2016, 04:39 AM   #13
tucsonjwt
As Keith said, 3/4 tons and up are much heavier. My 83 C20 long bed reg. cab with 454 and SM465 weighs 5600 lbs. with me in it at the landfill scale (I weigh 210 lbs. soaking wet.) GVWR is 8600 lbs., so I can safely carry 3000 lbs. of payload.
tucsonjwt is offline   Reply With Quote
Old 01-30-2016, 04:43 AM   #14
tucsonjwt
Also, a 3/4 ton will tow a lot better and get much worse fuel economy.
Old 01-31-2016, 01:44 AM   #15
slotard
Most of the weight on a 3/4 is from the axle, your bigblock doesn't help. The frame weighs more, yes, but nowhere near as much as the axle.
1973 C20, 350/350
