Old 01-28-2016, 11:12 PM   #1
chewychevy67
Gas tank swishing sound when cornering
Is there any coating you can use on an in-cab gas tank that will make the swishing sound quiet down in the cab? Relocating the tank is not an option. Just would be nice to find a way to quiet it lot or even a little.
chewychevy67 is offline   Reply With Quote
Old 01-28-2016, 11:26 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Gas tank swishing sound when cornering
Originally Posted by chewychevy67 View Post
Is there any coating you can use on an in-cab gas tank that will make the swishing sound quiet down in the cab? Removing the tank is not an option. Just would be nice to find a way to quiet it lot or even a little.
You would have to pretty much remove the tank to apply any kind of coating otherwise you could only get it on one side and I don't think that would do much good.
LockDoc
Leon
Old 01-28-2016, 11:29 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
Stick chunks of gas tank foam down the filler neck.
Lizard skin/dynomat on the outside of tank might help.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-28-2016, 11:29 PM   #4
chewychevy67
It's for my build. The cab is in body shop stage. I just remember from when I drove it how annoying that sound was. I have a new tank sitting here and was just thinking while it was not installed yet what I could do to help this stay quiet. I know it still needs to ground out so I would mask where the cab bolts to it off.
Old 01-28-2016, 11:37 PM   #5
chewychevy67
Yeah dynomat might help. What is lizard skin? A paint on or a stick on?
Old 01-28-2016, 11:38 PM   #6
LockDoc
LockDoc's Avatar
.. I thought when you said that removing the tank was not an option that it was already installed and you didn't want to remove it from the truck....
LockDoc
Leon
Old 01-28-2016, 11:40 PM   #7
chewychevy67
Sorry my bad. I meant moving the gas tank to the rear frame under the bed. That would be the ultimate way, I just did not want 20 guys to throw that out.sorry. I edited my first post to relocating not removing.
Old 01-29-2016, 01:11 AM   #8
allchevy58
allchevy58's Avatar
I put Dynomat on mine, then put the factory cardboard over it and I can't hear the gas moving around anymore.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 01-29-2016, 01:14 AM   #9
chewychevy67
Awesome. Just one the one side facing the seat or all around? If all around did the tank fit nice and snug after
Old 01-29-2016, 07:00 AM   #10
Aus69c20
Aus69c20's Avatar
x2 on the dynomat option.
Without removing the tank I put a dynomat style product on first with a high density foam over the top. I did this on one side only and now I can barely hear it. Well worth it.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 01-29-2016, 07:44 AM   #11
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Hey Rod, keep it full of gas and you don't get any swishing
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 01-29-2016, 02:59 PM   #12
davepl
davepl's Avatar
I have dynamat strips (don't bother covering the whole thing, it's not insulation, doesn't work that way) and then the factory tank carpet, because I have buckets.
This has two purposes - the dynamat "deadens" the tank wall and the carpet is sound insulation.
Keeping the tank more full might help as well. Less room for the contents to slosh around in.
My Dad had to keep the tank level below 3/4 or gas would splash out of the filler neck and onto his shoulder, and since he smoked a pipe, that was dangerous. I suppose he -could- have fixed it, but he just chose to run less gas....
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-29-2016, 08:48 PM   #13
engineer_gregh
engineer_gregh's Avatar
I bought my insulation at Home Depot, its called Frost King. Comes in a roll and is sticky on one side. No more fuel sloshing noise.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 01-30-2016, 01:42 AM   #14
allchevy58
allchevy58's Avatar
Yes, just the one side.
Old 01-31-2016, 10:23 PM   #15
89AKurt
89AKurt's Avatar
Huh, thought this was the charm of these trucks.
Now I'll have to obsess about doing this.
1968 C-10 Long Bed Blue Cloud
1956 GMC 100 GYMEE
1969 Corvette that identifies as a Ferrari Daytona Spyder Fakerri
2016 Honda Civic EX-T Stealth
89AKurt is offline   Reply With Quote
