Old 09-21-2003, 05:18 PM   #1
rustyold69
student wrench turner
rustyold69's Avatar
T-5 conversion
i now this has been asked before but what is everything that i need to convert my factory three speed to a T-5 out of an S-10? What knid of clutch package do i need and do i need to shorten my driveshaft at all? Any help would be greatly appreciated.
1969 Chevy C-10 with 250 L6
2002 GMC Sierra 2500 HD Duramax with banks six gun
rustyold69 is offline   Reply With Quote
Old 09-21-2003, 05:46 PM   #2
c-tenkid
If you are going to put this behind the I-6 in your sig this would be a good swap.
If your going to put this behind a v-8 it's not such a good swap.THe t-5 is a pretty weak tranny.You couldn't get a t-5 behind a 350 from the factory in a third gen f-body because of how weak the tranny is.
First of all the t-5 is going to be longer than your 3-speed.So your driveshaft is going to need to be shortened.Also the 3 speed in your truck has a different crossmember.It bolts to the bellhousing.The t-5's is like an automatics'Also the your going to have to convert to a hydralic clutch.
Personally I wouldn't do it.
That's just me though.
69 c-10 lwb,Converted to 4x4,dana 44f,12blt,4 inch lift,vortec headed 355,th350/np203 34x10.50x15 swamper tsl's
c-tenkid is offline   Reply With Quote
Old 09-21-2003, 10:32 PM   #3
rustyold69
rustyold69's Avatar
it going behind my straight six, but i want to know what kind of clutch set up i need. I will probably make my own crossmember.
Old 09-22-2003, 12:29 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would skip the S-10 tranny. Get one out of a camaro, they are stronger, and I think the S-10 ones have a spline issue with small blocks (Non compatible...but I may be wrong)
You can try bolting the tranny to your old bellhousing, but I couldn't tell you if it'd work though.
