Old 01-29-2016, 03:34 PM   #1
landy
Hood differences through the years
So in searching through the forum I read that in 1979, hoods got a decorative ridge across the front. What about hood latch changes? I've got a '76 with bent hood syndrome and came across a hood from a '89 Sub that looks to be in good condition. Are the latches interchangeable? Will the '76 hood springs bolt up to the '89 hood?
Thanks!
landy is offline   Reply With Quote
Old 01-29-2016, 04:10 PM   #2
nvrenuf
Re: Hood differences through the years
The whole front flip is different from 81+.
John
'91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's
nvrenuf is offline   Reply With Quote
Old 01-29-2016, 07:39 PM   #3
E.D.75GMC
E.D.75GMC's Avatar
You'll need a 73-80 hood, or 73-77 if you want it to be exactly the same as original.
E.D.75GMC is offline   Reply With Quote
Old 02-02-2016, 11:40 AM   #4
jjmorrse
There used to be stiffeners to fix the bent hood, but it is worth mentioning that the hood was designed weak at that point so it would crumple in case of a collision. It may be safer to get lower tension hood springs instead of stiffeners. As stated above, those hoods are different. The early ones extended to windshield, and the later ones met at the cowl vent. The nose is different as well, as is the spring attachment.
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
